Glad I found this thread...
What is the perfect replacement for the stock air filter? I have used K&Ns in the past for my cars and they are simply great...unfortunately, they don't make a filter for the Spyder yet...I spoke with the company about this...not sure if/when they'll have one...some claim they do, but the company said they don't.
So, trying to follow what is being written here...who is 'Ken', and what filter is a better than stock filter...and how much better? I know a good filter can increase HP and improve the air/fuel mixture, thus meaning better mileage as well...
I am working with Ken on a "special project" - it's tame. He tends to frequent the "other" forum for whatever reason - in fact he's logged in there now.
There is a high flow air filter replacement for the stock filter - fits (better) in the box and an air filter and box replacement raceflow air filter. From what I have read that's usually coupled with his fuel pressure modifier and the O2 modifier.
Your combo - including exhaust and performance goals - will dictate what pieces you need.
That's true of pretty much anything including - for example - Two Brothers JuiceBox.
From what I have read "there" with the high flow air filter replacement (not the raceflow) and the Hindle you may also want to try the O2 Modifier, but others - including Lamonster - have had good results without also using the O2 Modifier.
I have none of his - or any one else's stuff - yet.
if you have not noticed
spyderlovers.com=nmn's site
other site=ken's site :dontknow:![]()
I have Ken's race air filter set up. Works very good. I also have air tubes from fog light holes to air filter for cold air. If you run the fuel pressure at 63 lbs you can put the o2 sensor back in and it runs great with a little fuel milage back. I have no drivability problems with this set up.(no surging,stalling,good increase in HP)
Ken had a banner ad on the front page here for free for months. He couldn't even bring himself to say thanks when I asked him if he knew about the ad.
NMN has been very appreciative of his banner and has done more to support this site than any other vendor. This is not NMN site and Ken had the same opportunity as NMN did because I didn't know either of them when I started this site.
I also happen to think that NMN has more passion for the Spyder than any other vendor and has produced more unique products for the Spyder than any other vendor. So call it what you will but it was Ken's choice not to support this site, not mine, all he had to do is say thanks and his ad would have stayed up. Go ahead and ask him about that next time you see him.
As far as Evoluzione goes, I haven't dealt with them yet...I was just looking for a performance filter to get a bit more out of the bike...nothing too fancy for me...I noticed it is $70.00 for the filter...that's a bit too steep, IMHO...a filter should be 30-40.00 range...any other options besides re-doing the entire air intake system?
