Error Code C1282 on 2012 RSS SE5 + Fuel issues/no start?
To the brake issue - is it fixed? On my Spyder (2008GS) it was the VSS not having been bled - probably ever. I found a easy but messy way to bleed it. Pop off the right side panel, shine a flashlight in front of the engine pointed down. You'll see the brake lines going into a block mounted on the center frame. Use a 1/4" ratchet with extensions with a 1/2" socket and you can drop down and get it. The messy part is can't catch the fluid. Then repeat the pump and hold procedure. Viola!
Bled this bleed screw. Actually got a hose on the bleeder screw after removing more tupperware (I had previously bled all the brakes and topped off the resevoirs).
Then followed the instructions to cancel the warning here
Voila! NO MORE BRAKE FAILURE WARNING!!
Thanks, Steven and everyone else. This forum ROCKS, especially since my nearest dealer is an ocean away!:2thumbs:
