Engineering Idiocy
Or Harley-Davidson with a horizontally mounted screw-on canister oil filter (like a car) directly above the rectifier. You can't change the filter without making a mess.
I'm pushing 80 and can afford to pay the dealer. I do everything on all our vehicles to keep active so old age doesn't set in faster. I'm currently installing a larger fuel tank in my Chevy 1500 3.0 Diesel. Crawling around under the truck doesn't seem like fun, but I still enjoy it.
My 1956 Ford V-8's plugs are easy-peezy ..... since it's a small block Chevy motor!! LOL IMG_2603.jpg
I got an Email from Can-Am recently that had a short video about doing an oil change on newer Spyders, so I thought I would watch it. Pretty straightforward about draining the engine oil, and then the transmission oil. THEN, it came to replacing the oil filter, and I was dumbfounded to see that you have to detach the brake fluid reservoir, pull it out, then secure it with a bungee cord to the right floorboard in order to get the old filter out and install a new one. Really? Whoever thought that one up gets the Darwin Award, yet another in a long line of Darwins that BRP has been awarded over the years.
It sure beats taking a friggin mirror off to change the oil.....moving the reservoir to the side is a piece of cake.....seems dumb, and it is, but it's much better than the previous cluster #$%^ on our 2016RT
I worked in auto manufacturing for over 30 yrs and a lot of things are designed so that you will bring your Auto in to the service dept so you will be charged
I had a DRL burn out on my Buick Enclave. The Owners Manual said to go to a dealership for replacement! Not an owner replaceable part. I looked on line for procedure and did BOTH sides myself in about 15 minutes. YouTube is our friend.....
