Peteoz
Well-known member
"KILL SWITCHES" are generally considered "emergency KILL switches." And yes they are there for a reason. But not to shut off your machine on a regular basis. That's what the key is for. (IMO)
Maybe I'm wrong here: But if you just hit the kill switch, the "system" is still draining the battery. ~ And that is a BAD thing. Especially if you forget. (leave key on in garage etc.)
Yeah, I agree completely re hitting the Kill Switch and forgetting the key, TRLBLZR1.......and I am bound to forget. I just want to make it part of a routine so that knowing where it is, is automatic. I might actually use the key to power off and then hit the Kill Switch. Not the recommended routine, but it will achieve a purpose. I know from experience with hazard lights on a car, that when you need to use them in a hurry, you can lose precious seconds trying to find the switch, with vehicles bearing down on you from behind :shocked:
Pete
