Ask service for a copy of the BUDS RPM report:
I will ask for it, Thanks.
I know, I know...Wow, not sure how I missed this either.... I bet Doc doesnt agree with this.... :roflblack:
and, "suspect mods" are ....?
Well there is something rotten, They first asked for pictures and after they review them, They asked my dealer for the BUDS report. Oh yeah, My dealer said that he couldn't access the information for rpm thru BUDS. BRP had no intention on covering repairs from the start. IMO
Really?!? :shocked:Oh yeah, My dealer said that he couldn't access the information for rpm thru BUDS.
They probably have some other bullets to break out for this battle; but this one is just too weak for words... :gaah:
I know, I know...
However, did one asked why BRP doesn't make a "black list"of mods? Instead they rule warranty "case by case"?![]()
If there is an overrule rev limiter mod, I want it! nojokeIs there something in the Fuel Management add-on that may modify, or overrule the rev limiter?
If there is an overrule rev limiter mod, I want it! nojoke![]()
I went and looked at the instructions that came with the controller and here is a direct quote off the instructions:
Won’t interfere with bike’s stock sensors
and inputs.
The controller that i have is the regular Juice Box, It only has the mode buttons to make adjust, unlike the pro which you can connect a computer to.
There is another page that has one line listed as "maximums". Mine had a max at 8829 but it showed 0% in the 8000-9999 range on the chart.
Is this report what your dealer sent to BRP or did he do some sort of data transfer to them?
OK, I see the page you're talking about, It does show 11008 RPM. Also it has low system voltage. That night when it happened i remember it was dragging on start up and right before it locked down,The lights were flashing on the screen. My dealer said he sent them a electronic copy to them. If the voltage is low, Could that cause false readings ?
Question-1: If BRP has a RPM limiter installed to prevent high rpms & possible damage to their product (the very reason for the limiter), then HOW did their BUDS system record such a high rpm if their limiter was working & correctly & was properly set?
:dontknow: :dontknow: :dontknow:
Question-2: Why was there a "low voltage" recording @ 11k rpms? At 11k rpms (well above the 4k necessary to record a "positive charging" status of the electrical system) there should be zero recordings of a "low voltage" fault unless there is a problem.
More questions than answers at this point....lets hear what BRP has to say. I would not like to think that riding above 4k rpms was insufficient to charge my battery and leave me stranded!
Does not give me that warm fuzzy feeling of "confidence" that my ride will NOT leave me unable to start it after stopping.....
