I have a 2016 RT Limited. <2500 miles. Experiencing slight piston knocking after cold start. Wondering if others experienced the same and if so possible cause? Friend with similar unit does not have same experience. Does new engine oil filter have back flow regulator? Love the new ride and want to stay alert to potential problems. Mechanic at dealership does not have immediate concerns. Using Amzoil. Changing oil and filter again as precaution. Does oil filter or oiling system have a valve that prevents oil from draining back into engine oil sump/pan when engine is shut down? After a day or so when starting I get heavy metallic knocking sound that goes away after pressure builds. Connecting rod? Hydraulic valve lifter?
