..EMERGENCY .. for 2022 RYKER owners - recall on Handle-bar bolts!
...... Wish I could just go out and buy the bolt and fix it myself.
Remove yours, measure length, inspect if either minimal thread contact or bottoming.
Then get longer (105 mm?) or shorter (95mm?) from M8-1.25x100 (8mm - 1.25 pitch x 100 mm) grade 8.8
Probably not at Home Deport or Lowes, but very likely at Ace or TrueValue or autoparts
Has anyone measured the depth of the hole and the depth of the thread.
Also some have said the bolts are breaking and some have said the threads a are striping on the bolt.
Anyone know for sure.
You have to realize that many Ryker riders are not very mechanically inclined. Doing this task may frighten them to high Haven. Some have never changed their oil (correctly), or even had greasy knuckles. They may want to invite a friend or neighbor along that knows how to read his torque wrench.
Yes, and a major benefit of a forum for those who are mechanically inclined.
My post #62 response was in answer to post #59: "Wish I could just go out and by the bolt and fix it myself."
To fulfill that wish, the bolt can be removed, length measured, then inspected if either minimal thread contact or bottoming.
UPDATE: NHTSA BULLETIN IDENTIFIES BRP PART NUMBER 230680054 AS M8X100 AND REPLACEMENT AS 5 MM SHORTER = 95 MM.
IT DOES NOT IDENTIFY NEW PART NUMBER
If a grade 8.8, 8 mm - 1.25 pitch, 95 mm length not available at Ace or TrueValue, order from McMaster-Carr.
McMaster part number 91280A174 is "Medium-Strength Class 8.8 Steel Hex Head Screw, Zinc-Plated, M8 x 1.25 mm Thread Size, 95 mm Long"
Package of 10 for $8.85
Since shorter is the answer, then your suggestion of a washer/spacer in post 4 of this thread may be an alternative to a shorter bolt
https://www.spyderlovers.com/forums/showthread.php?132391-Ryker-handle-bars-loose-knocking
https://www.google.com/url?sa=t&rct...503-7727.PDF&usg=AOvVaw0iG9f19YmCZPyoh5pyDf1f
Link excerpts:
Those vehicles have a handlebar stem bolt that may not have sufficient thread length
for a proper assembly by dealers during the predelivery preparation. They may also
have debris in the steering column before the assembly. Not all MY 2022 vehicle
identification numbers are included as some will be sent to dealer without the bolt or
already with the new bolt. The preliminary quantity of vehicles in this population is
9353.
Production Dates : FEB 25, 2021 - JUL 05, 2022
The handlebar stem bolt does not have a sufficient thread length to account for
all the tolerances stack of the assembly. Also, debris may be present in the
steering columns which could interfere with a proper assembly. This assembly
is performed by dealers during the predelivery preparation.
Component Name 1 : HEX. FLANGED SCREW M8 X 100 (old)
Component Description : Handlebar Stem Bolt
Component Part Number : 230680054 (old)
The assembly of the handlebar stem bolt is done by the dealers during the predelivery preparation.
From January 2022 to April 2022, BRP received reports from dealers that this assembly could be hard to install
and some of them were reporting that they were breaking the bolt during the process.
In May 2022, BRP received 2 reports of broken bolt while riding. One of the 2 resulted in a loss of control and
the driver had a sprained ankle.
BRP reviewed all the reports to identify the root cause as it had not broken during the predelivery assembly by
the dealers. BRP was looking for possible variations in the assembly process procedures or in the parts
involved in this assembly.
It was found that starting from MY22, the steering stem dimensions were affected by a manufacturing process
change of the steering stem. Although, it was still within tolerances, the dimensions were significantly different,
and the handlebar stem bolt’s threads could be too short to ensure a good assembly. It is also possible that
debris are present in the steering column before the assembly.
Consequently, if there is a sudden loss of friction between the cones while cornering, the trajectory of the
vehicle could be affected following a Vehicle Stability System intervention due to the play created between the
stem and the steering column.
With all the information collected and analyzed, BRP decided on July 7, 2022, that it had enough information to
report and wants to proceed with the repair of the affected vehicles population with a safety recall.
In the United States, BRP received 56 reports of broken bolts during the predelivery preparation , 2 while riding and 3 with an unknown riding condition. The accident report was from the United States.
The solution is to clean the threads of the steering column and to install
the new steering stem bolt.
The safety recall will be launched by the end of this week. The repair
procedure and the parts will be available at the time of launch.
The new handlebar stem bolt is 5mm shorter with the same length of
threads as the previous one. The 5mm reduction provides the necessary
space in the threads to absorb all the manufacturing tolerances of the
components in the assembly. Other differences (washer, scotchgrip) are
only present to allow prompt parts availabilities but are not related to the
recall issue. BRP will also instruct its dealers to clean the threads of the
steering column before the installation of the new bolt.
As part of the normal process, this assembly is not made during
production. The vehicle is shipped with a kit for dealer to complete the
assembly during the predelivery preparation. Vehicles not included in the
recall are shipped without any handlebar stem bolt in the kit and dealers
will later receive the appropriate component. As parts are becoming more
available, BRP will ship vehicles already with the handlebar stem bolt in
the kit. The last production date of vehicles included in the recall is July 5,
2022.
If a grade 8.8, 8 mm - 1.25 pitch, 95 or 105 mm length not available at Ace or TrueValue, order from McMaster-Carr.
If longer is needed, lengths available jump from 100 mm to 110 mm, not finding a 105 mm(checked Grainger, also)
If shorter is the answer, then your suggestion of a washer/spacer in post 4 of this thread is an alternative to a shorter bolt
Meanwhile, the question is still not confirmed if the replacement required is shorter or longer.
If 100 mm bolts were too short, so that only a thread or two engaged, then those threads could have stripped, rather than the full cross-section of the bolt sheared.
If only 110 mm are available, other than from BRP, and 105 mm is ideal, then a spacer or washer(s) under the head would work well and avoid parking for a month or two.
I don't have a Ryker, so no dog in the hunt ..... Has anyone looked at a parts Fiche', it will tell you the SIZE of the OEM bolt ...... just sayin .... Mike :thumbup:
I removed mine on a 2020 model and blew and cleaned out the hole. Took some calipers and mine read 105mm depth. My bolt is 100mm long and I also added a washer to mine. I'm thinking of a 10.9 strength bolt and do away with the 8.8. I would not go no longer than 100 mm .
David
David
Is it a blind hole or does something mount up against the other end? I'm asking because blind holes are typically not threaded all the way to the end unless they used a flat bottom tap.
Who knows. You would think they would use a bottom tap, but would also think they would use good bolts from the factory.
David
I called the BRP phone number right off of the page that talks about the recall. They set me up with a tow to dealership free of charge.
I took my 2022 Ryker Sport to Andres Powersports in Montrose, PA today. They replaced my steering stem bolt under recall in about 35 minutes. These folks were very nice to me even though I purchased the Ryker elsewhere. They also can do laser alignments so I'll take mine up in the future to see if they can correct the "Jitterness" on the hiway. On smooth roads, its not too bad handeling but on rough roads (We have too many here in NEPA) it beats me up riding. I came from riding Kawasaki's and lastly, a Suzuki Burgman 400 cc scooter.
" Jitteriness " ...... I suspect wheel / tire imbalance ..... a good spin balance should fix it .... If you have Kenda tires it could easily be " defective " tire/s ..... good luck .... Mike :thumbup:
Let me ask you guys a quick question. Would you agree that the 2022 Can-Am Ryker rally and the 2021 Can-Am Ryker rally, with the exception of cosmetics, are exactly the same bike?
Keith
I think we’re making a mountain out of a mole hill. I bought a new rally on June 30, 2022. This was two weeks before the recall. I was on a long-distance trip on my previous ryker and ran into mechanical difficulties 1000 miles from home. To get the replacement part necessary for the fix, it was going to take a week and I did not have a week to sit during my vacation. So, I traded my 2019 for a 2022 - both Rallys.
So, I traded on the spot and continued on my trip. Since then I have 4500 miles on this new Ryker. No issues whatsoever. I have an appointment for the recall for this coming Friday but because I did not want to park the bike, I simply went to my neighborhood Ace Hardware store and purchased an 8x100 Hex flange head bolt and replaced the suspect Bolt and torqued to 18 pounds. No big deal.
Now you may want to sit down if you’re not already sitting - The cost of the replacement bolt was $.24. They considered general hardware and price all individual pieces cheap.
I have to agree, I think BRP is just trying to get ahead of a potential problem and playing it safe.
Was the bolt you pulled steel or aluminum?
Others have talked about the BOLT possibly being Aluminum ..... Professional Bicycle racers who think in terms of GRAMS for weight saving wouldn't use an aluminum bolt for any critical component on their bike...... Aluminum for a Steering bolt is just not even possible ...... JMHO ..... Mike :thumbup:
Keith
2022 has the different wheels, which could potentially be a difference in mass.
2022 also has remote adjusters for the front shocks.
Later,
EV
I don't think there is a any of steering stress on that bolt.
Watch the video that EchoVictor put up (#44) and at the 2:20 mark it shows the handlebar mount being installed.
It has large piece that inserts into the steering shaft. There is a tab that fits into a slot. This is were steering input would go.
All the bolt does is hold everything down.
If the bolt broke for any reason, the mount might vibrate up and disengage the tab.
