DoseYDoes, Error Codes & Limp Modes
spyderCodes
I think the Spyderdom is separated into two distinct camps with maybe a few that sort of hang out on fringes of the two camps.
One camp is comprised of Ryders who are genuinely worried that some kind of error code is going to befall their ryde.
The other camp is comprised of Ryders who don't think about or have some understanding of what it means and realize that the event does not signal the end of the world.
Like a great number of subjects I could be completely wrong about this hypothesis.
I would like to get people to move out the first camp and make their way to the second.
Sometimes people in the second camp instill apprehension in people of the first camp by merely talking about such things.
I may be one of the few people who has actually read every word of explanation to every error code the Spyder is capable of producing.
Reader's Digest Version:This or that happened and here is the best guess as to why.
Nobody likes to be inconvenienced.
Limp Homes and Error Codes represent usually if not a major disruption to your plans then a real PIA.
But, unless you have some on going issue that requires attention ---------
THEY SIMPLY DO NOT HAPPEN AS OFTEN AS SUGGESTED BY A DIP INTO THE DEEP END OF THE INTERNET POOL.
When or if they do appear there are a few strategies that can either make them go away, or be managed so as to keep you and spyder safe.
Let's take the Limp Home Mode first.
This can happen upon initial start up, or while you are just cruising along.
Limp Home Mode has been modified to be less intrusive.
Engine power will be reduced but you should be able to make it to your destination albeit maybe a bit slower.
Limp Home Modes are triggered when your Spyder detects some kind of fault.
I suggest you try this experiment.
Unplug the passenger seat switch located underneath the seat.
Start your spyder.
You will be in Limp Home Mode.
Drive it around in a parking lot and see what happens.
I bet you won't find it as horrifying as you think.
Now of course you can get out of Limp Home by simply plugging the switch back in.
And guess what?
A bunch of limp home modes can be cancelled with actions as simple as that.
Sometimes just a simple restart will clear the trouble.
Other times not.
Take the time to calmly assess the situation.
Is there anything obviously wrong such as something bent, broken or disconnected?
You have a cell phone, use it if you have to.
Error Codes are produced by your Spyder's control system in surprising numbers.
Most you don't see.
Some you do.
An error code is a number that corresponds to some kind of unusual behavior.
The one possible exception is the P0000. It isn't an official code but seems to pop up to reset the system after something happens.
Seeing an error code upon start up might mean the spyder won't start.
You might not see a code, but an indicator light will come on to alert you something is wrong.
You then should do the three finger BRP salute and press MODE-SET-TURNSIGNAL CANCEL.
If done properly, the screen will change and either be blank (no codes) or show one or more 5 digit codes.
I have no idea why BRP didn't elect to put a short explanation of these codes but as yet they have not.
Pretty much the same thing happens when you are driving.
A light comes on and you go may or may not go into Limp Home Mode.
You pull over, do the BRP Salute and decide what to do.
It might require a cell phone call, but it might be something as simple the rear cargo door is open on an RT.
Nobody is suggesting that you should rip the tupperware off and start wrenching along the road.
But, like any type of unplanned for event it is helpful to be calm, gather all the info you can and then decide a course of action.
You can handle it.
Life is good.
:D A calm approach; from a voice of reason... PRICELESS! :clap:
(I like the experiment of unplugging the passenger seat sensor. :thumbup:)
:agree: Sometimes, just sitting back and taking a deep breath instead of going into panic mode helps.
Great info...
:bowdown: for the write-up. Great info for the newer or unaware how these machines think. The check engine light is another goodie. I know it would be crazy to have a light for each reason that one can come on but it is scary when it does come on. Then it goes off when you restart and you never know why...Thanks again for the app can't leave home without it.....:bowdown::bowdown:
The orange Check Engine light and the yellow VSS light are the two biggies.
It's really wonderful that you have such a positive upbeat attitude. However I see you didn't mention the D.E.S.S. issue, and the last I read you think it's overblown as do many many others here. But those that have that opinion are the ones who haven't EXPERIENCED IT........YET... !!!!!. IF it happens to you I wonder if you will come back and tell us what a NICE learning experience it was.......I'm betting you WON'T......Mike :thumbup:
:shocked:
attachment.php
Mike, Mike Mike.
I have had many issues not chronicled on these walls.
But my friend it is a matter of perspective.
So, before you decide to play the "It hasn't happened to You card" I suggest that you take a deep breath and think about it
I recently called out someone who falsely said the BRP fix did not work, and you supplied additional support.
OK, maybe that doesn't fit into your view of things, then show me where I am wrong with facts, not what ifs.
I like to think I'm fair and being fair means I don't jump on every bandwagon that comes along.
I try to believe as many true things as possible and as few false things as possible.
Roger--what more can I say? You are the "code" man. :bowdown::bowdown:
I am in camp #2. I don't worry about codes happening on my rides. If I get more than 50 miles from my home, I am toast as far as dealer fixes. There are no more dealers to stop into or call for help. It's tow time. The dealer from Anchorage (our biggest city) no longer sells or services :spyder2:. The local one (for me--Eagle River) now does service only--and they have not had a mechanic to work on :f_spider: for a couple months. The selling dealer (Wasilla), I have not yet been to because they are down the road a long ways. These events have affected my desire to invest in :ani29: #6. I am now in wait and see, but it has nothing to do with :spyder2: codes.
If one looks at my signature, there are five :ani29::ani29::spyder2::spyder2::spyder2:'s owned and over 125,000 miles traveled. I have had codes two or three times tops.
:ani29:: One limp mode home was caused by me. I rode the brake without knowing it. Damn those new boots. :roflblack:
:ani29:: A check engine light came on. It was low oil and it caused other issues. A quart of oil, and I was good to go.
If you keep the :spyder2: in good mechanical condition, you should be all right. Bad dealers, sometimes cause more problems than they solve. Good or bad--it seems to be a crap shoot on what you get. Last years good or best dealer can become this years nightmare. :bbq::bbq::bbq: I have said many times, when I cannot get good service to keep my :ani29: dependable, I will be out. :bbq::bbq::bbq:
Spyder, Spyder, Spyder ....#1.my reply didn't SUPPORT ANYTHING .....it just CLARIFIED..........#2. My post above did not refute ANYTHING you said !!!!!!.........My post concerned what WASN'T SAID .........Fair doesn't come into this ......And the D.E.S.S. issue isn't what I consider " AN EVERY BANDWAGON " problem..................And your " true and false " comment ...are you saying the DESS issue is a FALSE ISSUE !!!.... Like I said, if it happens to you, come back and give us a review of what it felt like......Until then, please don't THINK ...AND SAY....it's a minor thing that only occurs to a few.........Mike :thumbup:
Okay, I'm having a bit of trouble following you here but here's my best shot.
The DESS issue while troublesome isn't in my mind or experience the Godzilla proportions that you believe it is.
You are entitled to your opinion of course.
That's my opinion and I given the fact that it appears from the 19 page thread on the subject that I could only find 7 unique posts that reported the problem and of those 3 were fixed without any other occurrences including the OP and the rest, cheered on by folks who did not "yet" have the problem but are living either in state of luckiness they haven't or fear they might.
Is it a "false" issue?
I don't exactly know what you mean.
Do I believe it happens, sure I do.
There have been 451 Replies to the thread.
Here are posts from that thread.
26? Really??? :opps:
I should add one more: I do not currently, nor have I ever had; a DESS error message pop up. :thumbup:
My bike continues to run reliably, and I'd take off tomorrow for the Left Coast on it!
(If the Missus would let me... :banghead:)
This thread was supposed to be a bit of general info concerning Limp Mode and Error Codes.
It was not a post concerning any one particular malfunction or circumstance.
I will respond, if I respond at all, to the DESS problem in the thread(s) for that purpose.
I think I've said everything that I have to say on that topic.
I respect other's opinions and assume the same in return.
I like having the information for what can cause the Check Engine light to come on. Just last weekend we were out on a ride and the air temperature was 108. We were on the way home from lunch and the wife got overheated so we stopped somewhere to get into some air conditioning. There was no shade to park the Spyder in so we left it in the sun. 45 minutes later we were leaving and the Spyder showed a check engine light and I figured it was intake air too hot when I saw the thermometer on the bike at 127 degrees. Rode it home and got the code for high air temp. Nice to know what's going on.
I'm in camp 2. I know that :cus:happens - but don't get overly concerned about it until it does. I even rode my 2013 RT LTF across country last year, from WV to AZ and back -before the recall work was done - and it didn't burst into flames - not even once!
Life is too short to not have fun because something might happen - and, when it does, if it does, roll with it and find some more fun!
There have been 451 replies to a thread here ??? How did I ever miss that one :roflblack: :roflblack: :roflblack:
Life, for mE
Is to be lived without the "what if's". That thought mode is a major joy robber. Do I get frustrated, irritated and sometimes down right pissed if a situation is less than my desire. Yep. But no matter what happens, unless it is literally life threatening I say to self WOW a new life adventure. Let's chill and find best solutions (yep plans A - Z are sometimes necessary) and even then zip occurs. So I move to accept and move on. How I live and luv peace and freedom from drama.
Sooooo time for coffee and spending time with some the World's best people. Fellow Spyderlovers. Later
have an awesome weekend. :yes:
