BajaRon,
I haven't yet installed the ground, although fully capable of doing so. Is there a post or something that you could use to explain the "from here to there" for us with wire and stakeons.
Thanks in advance.
Let's not "shoot the messenger", I read everything to get an idea if there is something to worry about, resolution or not, etc., I don't want a censored version. Honest, open communication is why we are here, isn't it?
Also, when the steering issues were first brought to light, BRP, and some members of the various forums, just pooh-poohed it, and look where we are today
I'm getting a small fire extinguisher to put in the trunk. I had the ground wire installed, but who knows if this is the answer!
Awe, come on...someone has to get shot! :roflblack:
Anyway, BRP apparently tested both models and due to the auto shifting mechanisms, the grounding is only needed with the auto...no issues with the manual...people can do the grounding on their own, but there is no need...nothing can get affected as in the autos...
Although there may be no issues with a stock manual Spyder, quieting the electronic "Noise" created by the coils is not a bad idea.
What about radios, electronic cruise controls, GPS, etc., that rely on electronics and computers of various kinds to function properly. For instance, it could reduce talking distance on helmet radios.
When one of these devices give you trouble or do not work as well as they should, are you sure that it isn't coil noise giving them fits?
As easy and inexpensive as this "Fix" is to do I think it is a good idea. Granted, it might not do a thing for you (especially if you never intend to add any electronic device). But this is the worse case senerio to a quick, easy, cheap upgrade.
And I agree, we shouldn't have to do this. I would guess that BRP will begin grounding all Spyder coil packs in the future. Live and learn.
Most aftermarket electronic devices would likely be shielded and as far as frequency goes, who the heck knows...the good thing is that the grounding is not needed for your bike to work if you have the SM5...if you have the SE5, you could have some serious issues...adding it can do no harm but I wouldn't worry about it with the SM5 as I would with the SE5...
Most aftermarket electronic devices are shielded to reduce average amounts of electrical interference to levels that device can tolerate.
Most OEM electronic devices are also shielded in the same way (as in components for the SE5).
My feeling is the coil pack puts out a lot more interference than (at least some) electronic components, both aftermarket and OEM, are able to deal with.
Which ones may be affected and by how much is all guess work because we don't have enough information. We do know the coil pack puts out enough noise to mess with some SE5 components.
Just saying, 5 minutes and a bit of wire seems like cheap insurance.
My 2008 semi-auto spyder went into the shop yesterday for its 6k service and steering recall. Got a call from them that they can't release my spyder until they get the part for a ground wire addition, meant to PREVENT FIRES!
And, best thing yet, the part is on backorder until 08/13. So the spyder sits at the dealer for 10 days.
They also told me that people should "trailer" their spyders to their dealer for this, not to ride any more.
WOW. Letters supposedly are in the mail from BRP.
I agree with you...5 minutes and a piece of wire...where are the pics again of this? I think you put the explanation above somewhere?
I called my dealer today and ask why I have not been called to setup a 9000 miles service. I had called two weeks ago. They told me they was waiting on the ground wire fix(on back order) and they would NOT put any thing that BRP did not approve. They said they could do the service so I made an appointment for next Thursday(closed on Mondays). They never said any thing about trailing the Spyder to them. ?????????????????????????????????
I think the root of this lies in BRP's policies for reimbursing the dealers. They must approve all warranty fixes specifically, dictating the parts to be used. They also set the labor hours they will reimburse. They probably will not authorize a dealer fix, since they have come up with a new part, so they will not reimburse an unauthorized repair. The dealer doesn't want to get stuck with the cost, so they decline to do the work until they have the part and the approval.Still have to shake my head at this statement. If you look at the pictures of the fix done by this member, what in the world is so unique or special about this that requres a "Backordered" part?
I know I'm missing something extremely obvious in all of this but for some reason, I am just not getting it.
I know you can't argue with the dealer though. Just doesn't make any sense. :dontknow:
:agree: I know the bottom line is important to the dealers, but they could probably spend a modest amount to do this fix themselves, and make a some friends for life. A sharp dealer could produce a dozen of these wires in an hour, easy. No advertising will ever be better than a satisfied customer, so I think it would pay off. If that attitude makes me a dinosaur like you, so be it. On the other hand, I worked for government for 39 years, what do I know about business?Makes sense in a twisted sort of way. I guess I'm all about customer service first and all the other issues being secondary. But this is 2009 and I need to catch up.
I can redily see waiting for an electronic sensor, a machined component or a critical tolerance part. But a piece of generic wire and 2 generic crimped ends? 10 days? 2 weeks? Really? This is the very best they can do for the customer?:dontknow:
Seems like we are in an age where all the planets have to be aligned first before customer service is even addressed.
I know dealers have their isssues as well. It isn't like they sit around figuring out new ways to give the customer grief....do they? :dontknow:
