That round ring thing with the cable looped thru it that's then zip-tied to the module is an after market Ferrite Choke that's been added/installed after the Spyder's left the factory by someone, probably after they'd experienced a few DESS issues, in an effort to try to stop any spurious signals over-riding & swamping the DESS signal between the antenna & the DESS Module; or maybe it was done in an effort to lessen the chances of the antenna itself being swamped by a stronger signal &/or to iron out any possible spikes in the signal..... :
This is what I get in my service manual. Sorry for the sideways picture.
That round ring thing with the cable looped thru it that's then zip-tied to the module is an after market Ferrite Choke that's been added/installed after the Spyder's left the factory by someone, probably after they'd experienced a few DESS issues, in an effort to try to stop any spurious signals over-riding & swamping the DESS signal between the antenna & the DESS Module; or maybe it was done in an effort to lessen the chances of the antenna itself being swamped by a stronger signal &/or to iron out any possible spikes in the signal..... :Doing this Ferrite Choke thing was one of the earlier BRP suggestions/attempts at fixing the DESS problem, altho it' since been revealed that doing this didn't seem to work too well &/or at all for many tho!! :banghead:
It seems the only 'solutions' to the DESS stopping you starting your Spyder randomly that might be available atm are for you to replace the various Modules as & when they fail or as DESS problems become too much of a bother, but be aware that if you do that, you're only ever gonna be replacing the original dud items with exactly the same items that are still very likely going to experience this failure again/eventually; or you can see if you can find someone to Disable the DESS & then never worry about it again! :dontknow:
That was for 2013 and earlier. The DESS was changed in 2014.
Thanks for the info. Funny thing is, we bought this Spyder brand new. It had been back to the dealer a few times for some warranty work but none of it was ever for a DESS issue. We just recently had the DESS issue, that's why I changed the module to the latest part number.
Is this happening to anybody that also has the little "barcode store reward cards" attached to their keys. I have an Air Ambulance card on my key and was wondering if this causes it intermittently. I worked for an auto dealership and Chrysler stated that it could cause interference with their keys.
Got the dreaded DESS warning this past weekend on my 2014. At least I got stranded in my garage!
Spent today changing and relocating the module. Found enough wire in the harness to put it up by the coolant reservoir. Will be much easier to change in the future if needed.
petew, What was the DESS module part number?
Thanks for posting the pictures.
What is your current spyder mileage?
At least you didn't get stranded on the road somewhere.
Deanna
Module part # is 710004916 which I believe is the most current
Mileage is right around 2500 , I purchased the bike 3 years ago with only 500 miles on it .
Can someone please PM or email me the procedure for replacing the Dess module? My 2019 RTL Dess failed after having battery issues. I will be ordering 710004916 asap and want to try doing this myself. Post replacement, does it need to learn the keys? Is there a procedure for that?
If by email , PM me for my email address
thanks very much
