dash gauge hole covers
Devious56
Ok, so I've disconnected my dash gauges (fuel and temp. gauges) and can not for the life of me find a vendor that is carrying the coveres for the holes. Can anyone help me out? Thanks much.
David
Just curious as to why you would want to remove the fuel and temp gauges?
Maybe it's as simple as esthetics, or excessive information or, at the risk of being slammed, perhaps it's a case of "ignorance is bliss." Disclaimer - ignorance being an absence of knowledge as opposed to stupidity or many of the other prejorative terms apparently common these days. Then again, all of these may be way off the mark. :D
Or because there are digital gauges built into your dash computer that are far more accurate and you want to use the space for other more useful instruments:yes::yes:
When I had my 2010 RT: I'd agree with you... :2thumbs:
But the auxiliary gauges in the 2014 (Particularly the fuel gauge.), are spot-on the money, and I trust their readings about 219% nojoke
If you disconnect the two gauges that are mount on either side of the dash, digital ones will show up on either side of center display. The digital ones are more accurate, and for me, easier to see. I will probably put a digital voltmeter on the right side, and a blank off plate or clock on the left side.
David
David[/QUOTE
If you want more than covers try JT's Spyder store. I installed a USB and 12v sockets in the place of gages:yes: bevels, with covers. Store is listed as a Spyderlovers vendor. :yes:
David[/QUOTE
That was the first place I looked, I swear I had seen them there before. I couldn't find them listed.
