Haze
Well-known member
After running a couple thousand miles on my F3 with a Cat Delete pipe, She has started to make a "Burble" sound not a true backfire, when I close the throttle.
Possible exhaust leak?
Do I need to change the gasket at the joint of the cat to the exhaust pipe. If so can I use a Honda gasket as in the 998 engine?
What gasket have you used?
Thanks, David C.
Thanks, David C.
