Converting 6 pole WAGS trailer to 4 pole square Spyder
Used trailer
What does each wire on the Spyder 4 square connector handle?
Sorry about duplicated posts. I hope extras deleted.
trailer wiring
Picking up trailer far from home. It has the amber turn signal lights. Could I take those wires to the respective 4-square and use them as both turn and brake lights and the red as only tail lights? I could change the lens to red which seems easier than re-wiring the trailer to separate the existing brake lights into turn/brake.
Thanks for all the help.
If you are in a time crunch maybe & only if you had informed escort to help:lecturef_smilie:
Just you & general traffic:yikes: No way,not me bud, Id find another way to transport it!
Inside a truck bed or another trailer with good lighting:coffee: Get it home & get the lights right better than rear-ended from crazy light issues.
Any guidance anyone can give will be greatly appreciated
Check out Hopkins 47975 - 4 pin square. I had to connect a 4 pin round to my bike. Bought a standard 4 pin round and this Hopkins connect and made up a short connect between the Spyder and the trailer.
The trailer has amber turn signals. That means it is not a 4 wire system like the Spyder. But we still don't know if the trailer is actually a 6 wire or 5 wire system. Highly likely it's 5 wire. Then you need an electronic converter and build an adapter using that. Here is an example of one I found when I did a google search. https://www.etrailer.com/Accessories-and-Parts/Curt/C56196.html It separates the combined right and left brake/turn into right turn, left turn and brake.
Used trailer
Thank you. This appears to be the solution. One of the reviews was for a Spyder. Some reviews mentioned a diode, is this necessary? Thank you again.
There should be no need for any diodes on a trailer. Diodes would only be needed if your where towing a car.
