RTWolfie
Intermittent Clutch Slip
Thanks for your input BajaRon. Both times I was doing a consistent speed on flat terrain. What would the optimal RPM be for cruising on a highway?
			There are 2 things that will kill the Electric Shift clutch.
1- Lugging the engine. Upshifting and riding at too low an RPM
2- The wrong oil. (A product which is not JASO rated MA2)
Free of these 2 issues. The clutch should last the life of the engine.
Shifting is controlled with hydraulic pressure, which is controlled by electric solenoid valves. If the ECU is not providing correct information to these solenoids, then you can have slippage issues.
