Clock and temp guages that replace disconnected gas guage and engine temp guages
ColumbiaSpyder
Hello all, earlier this year somebody suggested a clock and temperature guages to insert in place of the gas and engine temperature guages. I have tried to find that thread without success. Can someone suggest where I might find these? The ones I recall were sold in either a black face or white. Trying to suggest Xmas gift to family members.
Thanks!
Try putting Gauge in the Advance Search Box Top RHS
You will get seveal Threads ref Replacing the Gauges - Everything form how to do it to various types of gauges owners have suggested or fitted
e.g. http://www.spyderlovers.com/forums/showthread.php?41370-Replacement-Guages&highlight=DIGITAL+GAUGE
I fitted a voltmeter and a digital clock in mine due to bouncing fuel gauge issue
See pictures below - Voltmeter (LHS) and Digital Clock (RHS) gauge fitted to Spyder RT-S SE5 2010 Model
Hope this helps
Eddie Sheppard
Reading UK
I see how you put the clock on the right hand side, but does the wire have constant power for the clock?
Hope this helps
Eddie Sheppard
Reading UK
Thanks!
Just curious as to why you would want to install clock and temp gauges when you already have them on the Spyder. Once you disconnect the analog temp gauge, the digital one will show up on the digital screen and the clock is already on the digital screen.
Most folks I have seen go with voltmeter (or ammeter) and oil pressure (like mine).
My gauges were from PROSPORT Performance Smoke gauge series - See fitting instructions
http://prosportgauges.com/#
The Digital Clock has 4 WIRES - YELLOW Battery + (Memory to keep the time upto date when Ign is off)
RED - 12V+ Ignition Switch
BLACK - Engine Ground -
ORANGE - Dimmer control - Not used as this dims the display when the lights are on
as the Spyder runs with lights on all the time the display would always be dim
The Digital Voltmeter 3 Wiires - YELLOW Battery +
The reason I went with the digital clock is the display is larger than the cluster display - Easier to read esp at night
no other modifications needed e.g. Did not have to tap into the oil sender supply for oil temp etc
Eddie Sheppard
Reading UK
Eddie Sheppard
Reading UK
Thank you for the instructions on what wires to use, and another question. Did you wire both the clock and voltmeter together with the ignition wire and ground, or separate.
I agree with using the digital clock.
I'm a little old school I guess. I realize the time and temp are already displayed digitally. I disconnected the gas guage earlier due its inaccuracy. I like the "analog look" of the guages somebody else shared on the forum several months ago. I would share the link, but I can't figure out how to do it (lack of technical knowledge!). Anyway if you want to see what I'm looking at its on Amazon. Its called a Formotion Guage. There is a clock and a temperature guage. The pair sells for $70. You can get it with either a white backing or black.
I used seperate supply for both - LHS For the Voltmeter and a supply RHS for the Clock -
Ran from an additional Fuse box added to my RT - see this thread for details :-
Fitting Additional Fuse Box to Spyder RT
http://www.spyderlovers.com/forums/showthread.php?32118-Help-Can-you-identify-these-brackets&p=366988#post366
If you want more Mod suggestions try the Forum - My Spyder Mods section - Loads of excellent idears and How to do the Mods
from many Spyder Owners
Eddie Sheppard
Reading UK
Question about the gauges.....
Hope this helps
Eddie Sheppard
Reading UK
Looks really nice... I have looked around at other gauges and these really look nice. Have they held up well with the weather? Also.. can you see them pretty well in daylight? Even though someone gave you crud on the site about already having a clock on the display, I am like you... cant see that tiny thing!!! So I think its a great idea as long as you can see it !!! So what say you????
Did you notice the last post was 2012?:shocked:
