We was told by Harvey (SpyderPops) that he suggest a certain "method" of shutting down and starting a SE5 or 6. Don't know if this is a solution or not, but we are doing it to preserve the clutch on our two roadsters. He says that the clutch has to disengage from 1st gear upon first starting with a dry clutch plate when you shut down your roadster in gear. So what we do is this.........
Before we shut off the engine, we shift it into neutral (N), then set the brake, then shut down the engine. Upon starting, the transmission is already in N, so the dry clutch is not engaged for shifting, we let it warm up to get the oil circulation up to pressure, then we put it in 1st and go ride.
Just what we do in hopes of keeping things in good condition for many, many years.........
