draboo
This brainstorm came to me while reading another thread.
1. Change oil, filter(s). Add precisely the correct amount of oil needed according to manual
2. Ride for 5 minutes to check for leaks.
3. Let sit overnight
4. Check oil when cold the next morning with a longer instrument and mark it where the oil level is and use this to check oil when cold.
Pretty much all of the motorcycles I ve owned in the past (the ones with separate tanks,anyway. Some of the ones with wet sumps had cool little windows to look at the oil level) I checked oil when cold. It is also nicer to check oil before you fire up and head out, then you know you are good for the rest of the day,at least.
