Changes to OEM Rear Tire Construction
sledmaster
It looks like BRP has listened. We’ve just learned that BRP has went back to the rubber compound of what the rear tire had back in 2012. A production change took place in June, so all rear tires produced from that point forward have the longer lasting compound, and they actually went back to the 2012 part number.
There have been many part numbers used for Spyder rear tires through the years as the compound has changed. With the 2008 GS it showed 705 500 958, but then went to 705 501 312, then to 705 501 464 (2012 compound), then to 705 501 604 (2013/2014 compound). (edit - there is also 705 501 180 as well.)
This tells us there have been five different part numbers for rear tires since the Spyder introduction, but they all used to supersede to the 2013/2014 number 705 501 604. Now they all supersede to the 2012 number 705 501 464.
When we told BRP dealer support about the unusually short life span we were seeing from the 2013/2014 compound, they confirmed the 2013/2014 rear tire (#705 501 604) was in fact a softer rubber compound and that they were aware of the higher rate of wear. The 2013/2014 tires have a rubber compound with more grip which, unfortunately, reduces its life span.
Now for the good part. No matter what part number you try to get, if a dealer orders a rear tire right now (or since late June) they will get the 2012 compound, as the part number supersedes to 705 501 464. That means if a dealer orders rear tires now or has done so in the past few weeks they will last longer, but will not have the same grip as the softer 2013-2014 tire.
Most dealers order a bunch of tires early in the season, so many will still have the softer compound. Have them check the part number – if it ends in 604 it is the softer 2013/2014 compound. If it ends in 464 then it is the longer lasting compound like what we had back in 2012. It looked like the pricing remained the same.
This info comes from BRP tech support, or maybe more accurately the parts guys in Sherbrooke, so it should be valid. Any dealer can verify this by entering any of these tire part numbers into their ordering system and it will show them what they will be shipped is the 2012 number, which is now also showing as the 2015 number – 705 501 464. This should mean all of the 2015s will be built with this longer lasting tire.
Hope this helps.
This is what it shows if you now enter any of the tire part numbers. Whatever a dealer orders, they are now going to get a 705 501 464 compound. OEM tires should now last longer, once again. IMG_20140829_170406_308.jpg
Thank you thank you thank you
Yesterday I had the dealer put a KUMHO on our 2014 RT L. We bought it in May.
my dealer is very very good with one exception, his only source of information re Spyders is from their "dealer network". I guess that is some sort of a dealers forum.
Any way, yesterday they told me that the reason for the reported poor tire wear was due for the most part to air pressure and that air pressure Must be spot on and monitored consistently.
i agree that air pressure should be checked but I think it is less of a contributor to this short life issue than is the coin pound.
I sent them a link to this excellentdisclosure
thank you
I'm glad that they reacted, but I've already switched to Michelin. Now if we could them to talk about a stiffer sidewall on the fronts :chat:
This is better than no progress at all but I don't think the 10000 miles I got on my 2012 Kendas is going to make me as happy as the 30000 I got on my Kumho at half the cost
Very good info. Thanks. Problem is, the dealers pull whatever tire they want off the shelf and invoice it with the latest part #. I bought a rear tire in late June and my invoice shows the 464 number. But the build date is early February. Next time I'll have to have them search for a tire with a build date later than June.
Interesting..!!
I got 22,000 miles on my kenda rear (RS 2012sm5). My fronts are still looking good. I replaced the rear with a kenda and will see how this one does. Still think the manufacture runs vary within a tears production. May be the country thier raw naterials come from...:thumbup:
I am with you and going to go with the Michelin tire as well. May cost more but the Michelin's on my car last way longer than any other tires I have used. They actually do run to the tread wear life as advertised!
Can I ask what Michelin tire you got?
I will probably need to replace mine after my Reading Ca. run early October. I have 9700 miles on my stock tire now and I am down to the water dams in the middle of the tire so not too much longer to go.
Bob
I had a hydoedge got 21k out of might have gotten another 10k but really like good traction wound up getting a defender happy with as well
Bob
I'm running a 215/60/15 Michelin Hydroedge. With 4000 on it now, it's holding up well. That's the problem I had. I was planning a long trip and didn'y want to start with a "marginal" tire.
The michlen Hydroedge is no longer available and the Defender is the replacement for it. (that is what my tire dealer said). I just put a set of defenders on my car, they have a 90,000 mile tread ware. Is there any reason a Spyder wouldn't get 40,000 out of one? I bought the T speed rated one instead of the V rated. The T is rated at 118 mph prolonged speed. the V is rated at 130 or 140 or something like that. Seeing as how I don't think I'll be driving at 100 plus for any length of time I used the T rated one. They were about $20.00 cheaper per tire.
TIRE WARRANTY ? ? ?
:yikes:.....So if these soft rubber compound Kenda's wear out in say 6 to 7000 miles are they going to re-place them under WARRANTY ? ? ...Mikeguyver :thumbup:
More to Consdier....
The original post was providing information that BRP had changed their compound (and part number) of their OEM rear tire. Many on the forum want to use the OEM tire, thus such information should be of benefit to them. Especially since so many have been wearing out the 2013/2014 rear tires in short periods compared to the previous ones.
I had posted previously that the 2013/2014 tires were of a softer compound and that was one of the reasons why they were going bald so quickly, but many did not want to believe that. I came across new information that was consistent with the softer compound of the 2013/2014 tires, so it was shared.
I for one ONLY use automotive rear tires. And I agree, even if BRP went back to their 2012 compound, I will continue to use an automotive tire on the rear because I believe it to be of higher quality and it wears longer and wears more even. So far I have burned through three different types, 2 of the Kumho, 2 of the Maxxis, 2 of the Toyo, all in the 225/50-15 OEM size.
To that point, we have traditionally believed it was the weak and cheap OEM tire ballooning out at high speeds due to centrifugal force that was the cause of the center wear. Some also believe high air pressure to also contribute to the center section wear. I am of the opinion one should never exceed the 28 psi suggestion, and I believe running lower is going to wear the rear tire better. Even with the OEM Kenda I would suggest going no more than 25-26. I run 25 right now on both of my units with auto tires. That said, the center section still wears faster than the outer edges. Not as fast as the OEM tires, but it could still be better.
So maybe there is more to this than just tire construction and air pressure. It has been suggested the rear rim is too narrow for the 225/50-15 tire profile, and that the 215/60-15 or 205/60-15 widths are going to wear the center even better because the narrower tire will fit the narrow rim better. The theory is the narrow rim pulls the 225/50-15 tire in to the rim, leading to bowing out the center section out on the 225 tires, also contributing to the accelerated center section wear.
I am not proclaiming to know this to be fact, I am just throwing it out there for you to consider. There might be good logic in using a narrower auto tire simply from the fit and even wear on the OEM rim, not just cost and durability and more miles.
REAR TIRE WEAR ISSUE
:shocked:...:agree:.......Sledmaster , I also dumped Kenda a long time ago.....The narrow rim thing is something I have also thought about. When I switched out my rear tire on my 2011 RSS I tried a 205/60-15 and that tire had absolutely even wear across the width of rear tire which I found interesting.....I have purchased a Michelin Hydro as a re-placement for my rear tire on my new 2014 RT and this is a 215/60-15.....from I have read here most users have gotten very good wear numbers .........But is BRP doing any WARRANTIES on the BAD rear tires that you know of ........Mikeguyver :thumbup::thumbup:
