piperpilot75
I have no doubt there are a few threads on here about CB's but I cant find them. Am considering adding one to my 14 Rt-se6 , any good recommendations, pointers on helmets etc for this?
how is the range on your midland handheld? I have a midland handheld and it wont reach even a quarter mile. And, how the heck are you listening to your CB through your SENA? The midland handheld does not have bluetooth.
Not with a "hand held" either.You can’t get this integration with a handle bar mounted CB.
Do a Google search with the following in the search box: "CB radio site:spyderlovers.com". (Don't use the quote marks.) The forum search won't search for any word less than 4 characters.I have no doubt there are a few threads on here about CB's but I cant find them. Am considering adding one to my 14 Rt-se6 , any good recommendations, pointers on helmets etc for this?
Called Sena about that. Their answer was it won’t work with the Spyder. I got the impression they are not interested in making one for the Spyder. I guess they don’t think there are enough people with this set up to make it worthwhile. I guess I should call again and see if they will tell me how to reword the Harley-Davidson one for the Spyder.
What I would suggest you do, which is what I would do if I wanted to BT connect to my CB, is this. Buy the HD version of the Freewire adapter. Then go to Edsets.com, or maybe even just do a Google search. Ed has pinout diagrams for his lower headset cords that plug into the bike. Using those for a guide make up a short cable with 7 pin DIN connectors, female and male. Solder wires to the pins on the female end, which the Harley cable will plug into, and then solder them to the appropriate pins on the male connector that plugs into the Spyder connector. HD and Spyder DIN use two pins for the microphone and three pins for the speakers. The specific pins are all that is different. The HD connector has a pin for a handheld mic and the Spyder one a pin for connecting to the shield. I would leave both of those unconnected. Each one also has an unconnected pin.Called Sena about that. Their answer was it won’t work with the Spyder. I got the impression they are not interested in making one for the Spyder. I guess they don’t think there are enough people with this set up to make it worthwhile. I guess I should call again and see if they will tell me how to reword the Harley-Davidson one for the Spyder.
I'm working on trying to use one of those battery jumper units that can also charge devices and a USB/cig power adapter to power the CB and maybe it will put out better. The few times I've use the CB with AA batteries I can hear fine but some riders at the lead and tail end don't hear me. If I were riding all day with them, I'd get a shielded power cig power outlet to power the CB. It has to be shielded otherwise there will be engine static interference.
View attachment 167983 View attachment 167984
Have you tried a shielded cable? I wonder if that would help, really. The reason I'm wondering is I think the engine static is carried throughout the entire wiring harness. Shielding would help keep external radiation out of the cable but noise that travels in the wire. When my nephew and I went to Homecoming last year he used a handheld and SR10 that I had. It worked pretty good, but the range is limited as you've said. We couldn't use a 12 volt power cable plugged into the trunk power port. The static was so severe communication was impossible. I don't know how much better the range would be with a 12 volt battery source but I'm thinking not much. We did find however, that the batteries lasted for about 2 days plus of all day riding so I wouldn't be concerned about battery life per se limiting your use of a handheld.The range is not far as it uses AA batteries. I'm working on trying to use one of those battery jumper units that can also charge devices and a USB/cig power adapter to power the CB and maybe it will put out better. The few times I've use the CB with AA batteries I can hear fine but some riders at the lead and tail end don't hear me. If I were riding all day with them, I'd get a shielded power cig power outlet to power the CB. It has to be shielded otherwise there will be engine static interference.
