The trailer is an Alumna TK-1. Someone on these forums had referred to the Alumna brand. I was wanting an aluminum trailer but I hadn't planned on spending that much on a trailer! :yikes:
There was a place in N. GA that had them for $2700. I found a dealer in Macon, GA that had them for $2600. I had arranged with my Discover Card people to be able to charge it on the card so that I could get the percentage back. That way I could just send the money to Discover after I got the trailer.
While I was there, a woman was purchasing a spare tire for her trailer she had bought two years ago. I thought what a good idea. So I asked what would a spare be with a steel wheel, nothing fancy. He said since I was buying a trailer, $50.
So, we went out the hook up the trailer and guy went and brought over a tubular front wheel chock. I told him what a Spyder was and that his chock wouldn't work. So he said he'd trade it for the spare tire. Cool, "free spare tire". :yes:
I was looking at the hitch and asked them where the safety chains were? He stood back and took a picture of it to send to his distributor. Ooops! :shocked:
So they attached a set of safety chains.
The ramp is inside under the bed of the trailer. The back end of the deck slopes down about the last foot. The ramp slides out the rear after you release the two retaining pins on each side. Then you set it up on the retaining lip on the trailer. It has a lockable storage box built in the front of the stone guard.
View attachment 40850View attachment 40851I bolted the spare tire to the back side of the storage box. There is a pin through the bolt inside in case someone wants to take the spare tire. It keeps the nut from coming off inside. There are four hold down rings built into the deck. You can see two of them in the side view pix. It has aluminum mag wheels and radial tires. The spare is a cheapy tire. I had to buy a "bling wrench" to be able to change a tire. Both mag wheels now have a special lug nut on them too.
I may add some other LED strip lighting so I bought a sealed battery to be independent from the truck hookup.
As you can see, it sits low to the ground for maybe easier loading?
So, I got several savings all around.
