DR Buck
Cats are made to create substantial heat in order to better oxidize the exhaust gasses. The closer the cat is to the cylinder, the better it will function. Difficult to set up on a motorcycle and it's probably why ours are so large because of where it's mounted. Had they wrapped the exhaust, it probably could have been a smaller unit and still passed Leftyfornia requirements. The extra gas burned with the increased weight and restriction negates a good portion of the cats environmental benefit in our case. The replacement needs to be nothing more than a Y-pipe to connect the 2 cylinder exhaust pipes to the existing muffler. Surprisingly, there actually is platinum in most cat converters and sometimes even gold. Not sure why they priced it so high. I was really wanting this and jumped right over to their site to order it figuring it would be two to three hundred bucks. Guess it's a small market and you have to recover your R&D. Hopefully as the number of RTs increase and someone else jumps on the bandwagon, the price will decrease.
Considering there is a post where someone had one made at a local shop for $129, the price, even with ceramic coating is way beyond what I will pay. I would have jumped on an order if it was $300 or less. But as it stands now, this winter I'm heading to the local shop and have one made using "stainless steel".
