Here is my story with Carplay crashing, and even crashed the whole cluster while riding.
Also like all of you, I've experienced almost all of your issues.
I tried a lot of things. Sorry if I am very technical and IT related here. I'm in IT
- My Sequence: Turn key to on, don't start the bike yet. Let your headsets connect to bike (all headsets if you have two). Then connect phone, wait for Carplay. Start bike.
- My checks:
F3 Limited 2024.
iPhone 16 Pro, iOS 26.
BRP Software 710011541 (global firmware). CSS 6.0.10092. Bootloader 1.9.0.
Cardos Packtalk Pros for headsets paired to bike only, not the phone.
No VPN ON (I confirmed this one breaks the connection). For this, I made an automation in iOS to turn off the VPN when Carplay starts, and reverts back to ON when not using Carplay.
Certified or original cable from Apple, or an MFI (Made for iPhone) cable. I use a nimble 2.4ft braided (Powerknit Flex) cable, and metal connectors.
I also tested with my wife's iPhone 13 mini, and it froze at the moment Carplay started.
All tests are made connected to a Noco Genius 5 to prevent battery discharge issues.
Possible solution here:
- The one major thing I need to confirm because this fixed my unstable issues, even in the garage: I found today if you have Wifi networks configured in the bike, it will try to reach them, or scan them to connect, and at this time, your bluetooth will also break on the driver's helmet, which so forth crashes Carplay, because it needs the driver headset to be connected.
I tested this
twenty times in the garage this morning, turning off the key and starting from scratch. I also tested by not respecting the sequence, like leaving the phone connected, turning off bike, turning on the bike, or like plugging it in mid boot of the cluster, and it won't affect or freeze Carplay!!! Once the headsets connects to bike, Carplay starts like butter and stays alive. This is also very nice, within under 10 seconds of turning the key.
I will get the bike connected to a charger this afternoon, and play some music for a while to see if it breaks. I have a ride on Sunday, and will test it thoroughly then too, on the road.
So to recap,
1. All Wifi's deleted in the cluster to prevent scans.
2. No VPN.
3. MFI or certified cable.
Fingers crossed. I will report back.
If this works, BRP owes me money here.
