Can technology solve the hydroplaning issue with Spyders?
AND THE SOLUTION IS
I never said the use of emojis bothered me. I said that when used in a discussion of a technical nature, they tend to obscure the message.
Emojis are meant to convey emotion of some kind. The same with exclamation points. I don't think they help communicate an idea very well.
Just stop reading my Posts ....it's that easy.....:yes::yes::yes::yes:......Mike :thumbup:......... PS ,have you contacted the Administrator yet to have Him/Her remove the ability to use Emojis - yet ?????
Just another USELESS report .....they are talking about " Cars & Trucks " .... what occurs is really unique to Spyders ....not even conventional Trikes can be compared to the Spyder ...... Mike :thumbup:
Unless if you're one of those ryders using CAR tires. Then there might be some relevance, don't you think? After all, the tire doesn't know or care what kind of vehicle it's mounted on.
If I had a very light vehicle, say a Lotus 7, or Polaris Slingshot, running "rain" tires vs "slicks" would make a difference in the wet. I would guess a Spyder, other than the 3 wheels, might behave similarly with the same tire choice.
Have a look here:
https://www.nhtsa.gov/equipment/tires
One of the ratings on the sidewall is "traction" which is supposed to be "wet traction" but I don't know exactly what that means.
It might not have much to do with shedding water in a hydroplaning situation.
That's a good starting point, I think;
Traction grades are an indication of a tire's ability to stop on wet pavement. A higher graded tire should allow a car to stop on wet roads in a shorter distance than a tire with a lower grade. Traction is graded from highest to lowest as "AA", "A", "B", and "C".
Of current tires:
  • 15% are rated "AA"
  • 77% are rated "A"
  • 7% are rated "B"
  • Only 4 lines of tires are rated "C"
Then what do YOU suggest we do in trying to determine the relative wet traction ability of the different tires we are looking at for our Spyders?
I'd have to put you on the ignore list, and I'm not going to do that. Why are you so angry?
HYDROPLANING
Oh yes they do care !!!!! and they DO know
:banghead::banghead::banghead::banghead::banghead:
Instead of :banghead::banghead::banghead::banghead:, care to explain? Please, enlighten us.
Vertical and lateral loads on a contact patch are dependent on only the forces imparted by suspension geometry and vehicle weight.. .not the type of vehicle. Please explain how a Spyder's front suspension design imparts different loads than any other vehicle with unequal length A-arm and shock arrangement (like that on a Lotus Super 7 or Polaris Slingshot or formula ford)? The physics are the same. The coefficient of static and rolling friction, which relates to grip in the real world, are governed only by physical laws like weight and direction of forces, not type of vehicle.
You yourself are running Michelin Hydroedge car tires ... surely there must've been some rationale behind your choice.
RELEVENCE
I had to add something ( :banghead: ) to my post or it wouldn't allow posting it !!!! .......... and after reading your second paragraph ...well I'm so Totally in Awe I'm speechless ....... last sentence, - yes there was, two actually ....... Mike :thumbup:
For anyone reading this who actually wants to alleviate the perils of hydroplaning -
From my experience with it on my first day of spyder ownership on a few hundred k's ride to get it home through Melbourne on footy grand final day, got caught in a huge rain dump - turned to astonishment that three wheel spyder handled it so much better than two wheels
My two lessons that day
1 slow down when you see deep water on road ahead
2 (same as in cars) turn cruise control OFF if you don't want a nasty lesson at the end of the water..
Unfortunately, the Hydroedge tire is no longer in production. Anyone know what would be a good substitute?
https://blog.tirerack.com/blog/docs-advice-on-tires/the-michelin-hydroedge-is-a-great-tire
The Michelin HydroEdge is a great option for drivers who want a good blend of comfort and durability at a reasonable price.
It has been very popular with Honda Odyssey and Toyota Sienna minivan owners (among others) due to its low rolling resistance, superb hydroplaning resistance and year-round traction, even in light snow.
The dual circumferential center grooves and high-angle HydroChutes combine to pump water from under the tire's footprint to enhance hydroplaning resistance and wet traction.
thumb.php
Reading this thread and Chuck's thread about hydroplaning caused me to look at my tires and try to come to some conclusion. Tread on all three are at 80% or better. All three tires have 4 deep grooves going around the circumference. Makes it look like five narrower tires on each wheel. All have angled sipes in the contact patch area to channel water away from the tires. I feel as prepared as I can be. Lived in Seattle for over 55 years so know a bit about driving on water. Idiots, mostly driving 4WD vehicles, who don't SLOW DOWN, get passed by me as they sit in the ditch. Two other things to watch for are road track depressions usually caused by studded tires and chains. They fill with water and are our enemy. The other is to watch the tire track from the vehicle in front of you. If that vehicle is leaving a good clear trail, that is good. If the track disappears, that is bad because he just hydroplaned. All vehicles and all tires will hydroplane. Ride with your wits about you and slow down and all will be OK.
Now if we could just get some rain here. We haven't had ANY for 3 1/2 months. :shocked:
