Can signature light installed with switch to turn on and off?
Jwill
I only have seen one that will automatically on when engine started. Curious to know if there is one that controlled by switch on/off? If they have one what brand?
it comes on with the key if properly installed to the connector behind the frunk insert. Just turn on the key to light up your frunk with the lid open.
Erm. I may have installed it on the GPS circuit not the User circuit. Will check in a day or two.
When you install it you can always rewire it to a on/off switch placed wherever you want it to be. but it comes without a on/off switch.
Cruzr Joe
Lamonster sells a bright ryder that is the same thing, only cheaper. Easier to install also.
I checked and I have it plugged into the bike side supplied connector so it should work like the front fender lights - key on - key off.
