I'm guessing it is a cable for some oddball audio device. The 3 pins indicate to me Left, Right, and Ground of a stereo cable. The 7 pin round connector is a common DIN connector, which even though it has 7 pins, only three would be used.In the square end, there is 3 pins that are like a usb and on the round side there is 7 pins.
I know! It’s garbage! Pitch it.
As I said earlier, it's an attachment lead for the plugs in the trunk of your RT that should allow you to charge &/or control the sound output from your device via the dash & mode button, but it's old school & superceded now! So if you don't have anything that has a plug to connect with the old style square end, then it's effectively useless to you. :lecturef_smilie: . There might have been another curly lead like yours, cos the leads I have left out of those that came with my 2013 RT are slightly different to yours (see below), but that square end on the lead you have I believe went out of common usage back sometime around 2013.... probably best just to put it away somewhere & forget it. :thumbup:
G"day Peter
I am after a Ipod connector like the 2nd one in your first photo. Any idea where I can get one. (I have a 2014RTs).
Cheers and beers
Frank
G"day Peter
Cheers and beers
Frank
That cable does not look like it belongs to a Spyder. I'm not 100 percent sure but it looks like a cable to go from an old camcorder to a Firewire connector, decades old video tech. Hang it in your garage as a trophy.Was in my frunk on my 2013 spyder RT when i bought it..
