2010 Spyder RT - anyone know what vacuum hose goes?
Admittedly, the linked thread and the vid in it are about an ST, but once the panels are off, the RT's are essentially the same - I found this simply by typing 'Vacuum hoses' into the Search field (top right of the page); ticking the 'Search titles only' box; and submitting the Search, there's a heap more there if this one doesn't answer everything - check it out:
Good Luck! (y)
The Spyder he is showing in the video is not an RT so some things will be different. The first thing I noticed is the screws in the cover. He shows removing the chrome screws in the lower part of the cover. The RT has similar looking screws, but do not try to remove them, they are push in studs on the RT. IIRC, the hose ID is 3mm and you want silicone hose not rubber. Also, be sure to cut them the same length as the factory hoses. I chose to do them one side at a time. Good luck and have fun.
