kissfan
Addendum -- if you're on Facebook, here's the BRP Connect group
https://www.facebook.com/groups/2125926714370274
my new goal is as billybovine said above, so I need to install a USB charging port and not use the data cable.
Any hints on doing that?
Somebody has tried to connect to BRP Connect with MySpyne on the Android or apple mobile?
Fat cycle daddy, I just purchased my 2018 Spyder RTL and purchased the Sygic Navigation premium on sale. My problem is I can’t get Sygic past the initial setup to use the app. When I click on the grayed out icon it tells me to click Start which I do then it says click on popup 1 and then Popup 2 on my handset. Nothing shows up on my phone except the map in Sygic. I get no pop ups. Any advise on what I’m doing wrong?
...enable the Bosch MySpin.
Don't want to use BuRP Connect (and not many do), buy THIS https://www.amazon.com/gp/product/B00T0DW3F8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 . It's a data blocker. It will give you power to charge your phone but will NOT allow data through meaning you won't connect to BuRP Connect and you're phone won't lock up. I've used a data blocker (that particular link) for about 6 months. It works perfectly.
Okay, now this seems like a cool solution. Please help me to understand something though: If I connect my iPhone to the USB port in the small glovebox with the data blocker in place, so I can keep my iPhone powered, can I also play my iPhone audio (Spotify, map directions, etc) through the bike's speaker system by connecting the phone to the bike via Bluetooth?
Thank you for any advice or experience you (or anyone) can lend to this! I've made a deposit on a 2020 RTL and would like to know what hurdles I'm going to be facing.
Steven
Yes any music or sounds will be heard by the speakers (or headset) when the phone is connected vie bluetooth.
Although not positive about GPS sounds but if a GPS app is giving voice directions then it should interrupt the music.
You also have to go into the music and make sure the music is bluetooth and not FM radio.
Very cool. Thank you for sharing this. It just seems as though it would be so much easier to have my phone mounted on my bars (like I do on my motorcycles) and powered by the bike so I can see alerts, etc, all while using the iPhone to also play my music and perhaps even handle navigation. I don't make a habit out of using my phone while riding, but I also don't like being totally disconnected from that flow of information if my family or others need me or something.
Based on your description, I would have to assume that any noise the phone makes - Spotify, navigation instructions, alert sounds, & even the phone app itself - would all be directly routed to the bike speakers and be no different than what you would experience if you were using headphones or any connected speakers: All the noise/sound the phone produces, just sent to the bike speakers rather than the internal speaker.
That would make sense since that would be a completely different audio source.
Your response has been very helpful! Thank you very much! I was a bit concerned about being constrained by the BRP Connect ecosystem. I've been a GPS user on my bikes since GPS technology became available to the public and I rely on my iPhone (probably way too much) to keep me informed about the world and connected to my family and others. I'd hate to limit all of that to just what is provided by the BRP Connect system.
It sounds like I'll probably end up with the data blocker, a USB splitter, and some small cables off of the splitter to power the phone and a GPS unit -- both mounted to the bars.
Thank you again!
Steven
