Eviltwin
That should fix the starter problem. Might be wise to test that D2 diode while you got it open. It should be right by the solenoid. Test procedures are in the manual starter repair section. If the diode is allowing reverse current or two way current it will damage the system.
Maybe. Solenoid was closed, thats why the starter motor was running. He disconnected both wires and then reattached both. I would have left the heavy wire that went to the motor disconnected and checked for 12v on the thinner wire that should be coming from the the wiring harness. If that has power, that explains why the solenoid was closed. If it doesn't, then the solenoid is bad.
Now if that wire has power, then you need to keep going back to see what is energizing it. Somebody else mentioned a starter relay. I'm at work and cant check my bike to verify if there is one. That would be like a relay to fire a relay ;redundant. I've looked online, but cant find a wiring diagram. Somebody else that has a service manual can chime in about that.
