paulbrinker
Does anyone know if the Sena sm10 will pair to the Scala Rider Q2 headsets?
Only works brand for brand
The original poster wants to try and pair a Sena headset with a scala one I believe. That isn't going to work.
But the scala may be able to hook to the Bluetooth dongle on the Spyder for music.
Two totally different things.
Don't make the dongle mad!![]()
I bought the dongle with the harness at the owners event went to update the firmware and now only the red light (not charging indicator) comes on and the sena update software says device not recognized. Can't get it to alternate blue and red like its supposed to. Even tried resetting it with a paper clip. Anybody had this trouble? I'm hoping I hooked the harness up right did it in the wheels through time lawn that thurs afternoon. :banghead: Anyone else had this trouble with a brand new unit?
I did charge in the house and tried to see if it needed the firmware updated. Only the red light comes on now.Turn off, take inside and charge it for an hour or two. Use the USB cord that came with it.
You can't leave it on in the frunk. The battery dies and won't turn on unless it has a charge even if it is plugged into the USB.
