sjcpanther
Just got my new 2014 RT-S, and was needing to inflate my tires a few PSI. Took out my Slime portable compressor and plugged it in to the 12 Volt outlet in the rear trunk. Nothing. Turned on the bike, then it worked.
Worked for about 10 seconds then cut off.
Now I believe I may have blown a fuse, because my 12 Volt no longer works.
Question -- Should I have blown a fuse? Compressor says it uses 15 amp. How do I determine which fuse is connected to the rear 12 Volt outlet?
