Have you looked at TricLEDs? The sell a replacement for the red and orange reflectors.Does anyone have any experience installing blinking lights on the front fender of a 2015 F3 that can be seen from the rear? Since there are no blinkers on the front fender of this model, I suspect another wire has to be run and connected somewhere.
Do they flash with the turn signals?Have you looked at TricLEDs? The sell a replacement for the red and orange reflectors.
Good info. I find the dash lights to be nearly invisible in bright lights, so I can't see if the blinkers are still on or not.I have TricLED's fender lights and have them set for blinking (they alternate with the OEM blinkers.) Had a friend follow me yesterday and he said they are GREAT for visibility from behind...both the lights and the blinkers. They are not at all distracting when you are driving but I find them more convenient to glance down at (checking to see that they cancelled, etc.) than checking the dashboard. (Also, since the OEM turn signals on the rear of the F3 are so close together, the spread of blinkers on the fenders may be helpful to those behind you. ?)
And yes, there is a "blinker module" you have to buy to get the blinker activated.
P.S. - I originally thought to add the lights after following Copperman's RT and seeing just how much visibility from behind that add. (Thanks, Jerry!).
:thumbup:
Thanks Slagiatt! I think I'll talk to my dealer!Unfortunately, I have no idea how the tech did it, but my dealer's Spyder mechanic installed the rear-facing LED lights with blinkers on the front fenders of my 2015 F3 and they're on and working great. I assume he followed the instructions that came with the TricLED package.
Be sure that the person you're talking to isn't referring to the side lights that you can get for the REAR fender...those, I believe, can't be blinkers.
Anyway, I wish I had the competence level to tell you how he installed them, but turning the ignition key is about the extent of my technical knowledge. :dontknow:
There is no reason, as long as your bike has turn signals, that you couldn't make them work. It is just a matter of wiring. If the load is too much, usually a canbus issue if used, then relays could be used. It isn't genius level wiring at all. Since the LED replacements exist for the fenders, it should be quite simple. Certainly I have done it on several other motorcycles, no reason this bike should be any different.Unfortunately, I have no idea how the tech did it, but my dealer's Spyder mechanic installed the rear-facing LED lights with blinkers on the front fenders of my 2015 F3 and they're on and working great. I assume he followed the instructions that came with the TricLED package.
Jcthorne: I have the 2015 F3 base model. It has a yellow reflector on the side of the fender and a red reflector on the back of each fender. It also has the one white indicator light on the front of each fender as you can see on my posts. To my limited knowledge, I only have a power lead to the front indicator light. So then, if the wiring to "both F3 and FS fenders is the same," do I have a directional signal wire at the fender that is capped off and all I need to do is connect LEDs to it to blink? If so, that is great news.The wiring to both F3 and F3S fenders is the same. Its the rounded fenders on the base model that do not have the side and rear reflectors to be replaced with LED versions.
Here's the answer I got from TricLed:
Hi John, unfortunately for that fender model , we don’t have any LED and module that would make it blink.
The LED that will fit base fender model is our TricFenderz, its strip of light with dual color, either white or Amber towards the front and red towards the back, but it won’t blink.
Sincerely,
Cindy
Makes ya wonder......
