So, I have a 2015 F3 SM6 Spyder, and at 4k I encountered a slave cyclinder failure. It appears to be a Brembro part, but I could not find the part or a rebuild kit for the slave, so I ended up with a $200 part from Can Am to replace the slave. But you have to pull off the drive sprocket to get to a bolt that holds a plastic piece under the drivers side motor, and I am looking for info on how to pull the drive sprocket?
I came across an open recall on the front sprocket failure on 2015-19 Spyder F3's, and replacing the cyclinder was not a difficult job, just time consuming. if you have a 2015-19 Spyder F3, check for the recall.
