Hi vided,
Re: anybody have pictures or a diagram of where to place jacks?
Are you asking about a floorjack or jack stands? Only asking since your question uses the plural.
On my '08 I cannot get my floorjack under the frame when the tires are on the concrete because my floorjack sits too high when collapsed.
I put my floorjack under the suspension on one side, just inside of the tire(s), lift just a little, then a small block of wood under the tire, then repeat for the other side.
Once both tires are up about 2" or so, I can get my floorjack under the frame at the center.
Then I lift it up to either put blocks of wood under each tire ( I have a couple of 6 x 12 wood pieces ) or jackstands under the suspension on each side.
Does this help?
Jerry Baumchen
PS) Once I have it on jackstands, I always give it a good shake just to ensure that it is stable. I also do this whenever I am putting a car on jackstands. And make sure the parking brake is set. We wouldn't want any oopsies, would we? :yikes:
