Best exhaust on the market?
Considering the O2 mod enriches the mixture-- I doubt any MPG gains are coming from it.
It's a performance mod - not a MPG mod. Just don't want anyone expecting increased MPG from it. I sure as heck didn't gain any MPG from it--- but didn't want to or expect to. I'll gladly give up 2 mpg for better off the line performance.:thumbup:
Probably ordering an HMF this week as they are one of the only that can come in black/carbon fiber. I like some of the other options out there-- but hate the look of a 'shiny' exhaust can.
I have the 2 Bro's single can and like it. I average 30 mpg over the 27, I was getting with the stock muffle and haven't had any close calls with minivan drivers, since putting it on.
A lot depends on how loud you want your Spyder to be and the Hindle is also a popular choice. I wanted it louder for the safety issue and it also depends on your local laws.
Did you do the o2 mod and the exhaust at the same time?
No! Did exhaust first. Than new plugs, 02 sensor and new Honda "Y" gaskets, about a week later.
It ran a lot better after having all the codes cleared and updates done after installing the new dps, when I picked it up.
[ame]http://www.youtube.com/watch?v=hb1SfL9FkF0[/ame]
I don't own a spyder, but this sounds good and looks good. Wonder how loud it is in real life under WOT?
I got the Hindle installed yesterday and I expected a bit of a lower running temperature. It didn't. I rode home in 99 degree heat at 70 MPH on the highway and still hit 5 bars occasionally cooling down to 4.
Disappointed. Looks and sounds good though.
Installing the missing air dam this evening. Maybe that will allow me to run a little cooler.
Never liked running at 5 bars at 70 MPH. I would think that would be enough air even at 99 degrees to keep the temperature down. Oh, well.
gas mileage
I put on an aftermarket muffler. Compare the aftermarket and factory muffler, the factory muffler does give me more MPG than the stock.
I've tried a few different exhasts and this is the one I like the best. Very happy with my Yoshimura RS-3 Oval. I also like the TRS Tri version. Great sound and fairly loud when you ride it hard. Not that loud when you ride easy. I like a pipe that you can live with in long distance cruise mode. This pipe does not drone or annoy at crusing speed.
It also has a noise reducer insert (which I use) so it can be louder if you want.
I've run this over 10,000 miles and it's holding up very well. It also comes in Stainless and Titanium versions.
The Micron sounds great, very cheaply built and won't last, it is louder than the Hindle and the Yoshimura.
The Hindle is well made, sounds great and is louder than the Yoshimura but quieter than the Micron.
The 2 Bros. is louder than the Hindle, Yoshimura and Micron. Not sure it is as well made as the Yoshimura or the Hindle.
The HMF sounds great, is louder than the Hindle and the Yoshimura. About like the Micron, is well made and should last.
The Kewl Metal pipe that Doc used to run is just that, a pipe only, it is offensively loud (except to Doc who just enjoys a good aggravation). It should last forever since there is nothing to go bad.
I also like this one. Basically it's the same can but with a triangle shape instead of the oval I'm running.
Ron do you have a part # for your exaust i can't seem to find it on line, Also your statement about the Micron not lasting is true mine literaly fell apart on the highway Sunday [lost part of it] now i am back to stock :gaah: Or does anyone want to sell a Hindle?
Had a Micron, looks great, sounds great, piece of junk. But hey! It was fun while it lasted!
The 18" part number for the RS-3 - CRRS3186W
The 20" part number for the RS-3 - CRRS3206W
All you need is the muffler. All of the S/O kits come with a mid pipe but the cans are all the same. If you can get just the can you might be able to get it for less. But if you have to buy the kit with a Mid-Pipe just get the cheapest one you can find as the cans are all the same. The different part numbers have to do with the mid-pipe application.
The RS-3 is made for off road use. Maybe that is why it holds up so well.
Here is an example - http://www.morepoweracing.com/yoshimura/Yoshimura/p-1-39707
Thanks looking at the pictures it is a lot better built the the micron [held together with 2 rubber gaskets] :gaah:
There are probabaly more good exhaust options for the Spyder than any other motorcycle on the market because all you need is the 90 and just about anything out there will mate up after that.
Come to Lamont's BBQ and you'll be able to see and hear just about any combo you could possibly want.
We could have an exhaust look/sound contest! Just line up, rev up and let people vote! :yes:
I was looking at a hmf i found on ebay. Then i figured that Lamont's bbq is only a couple weeks away :clap: and i should wait. I would like to hear the SPX from No Magic
I'll have my HMF carbon unit on next week.... will bring it to SITS for you to hear......
