Best alignment to be found! Union SC.
Leaping1
If anyone needs the best lazer alignment in the world contact Sean (Triniman here on the Forum). He aligned my 2011 Can Am RT-S and I couldn't believe the difference. He has the lastest equipment for alignment on Can Ams and can also do trikes. For an added bonus he is a really good guy ready to help you in any way he can. He is located in Union SC.
Thank you Leon for your kind words. This was not a laser alignment system. It's a patent tool and process that uses a 3D aligner. Like you have seen, I have built and proven specs for single riders and dual riders. The accuracy of the alignment system is 0.01 degree for toe, 0.1 degree for camber and caster. The system will do regular trikes, reverse trikes, and autocycles like the Slingshot. The whole process of doing a Spyder alignment takes about 10 to 12 minutes with a print-out showing before and after measurements. I have had to keep it under wraps for the last two years, but during that time, I have been helping individuals that really needed help. One other thing to note, no more measuring tape or reference cards.
I can mount and balance your front tires. Sorry, I don't do the rear. Just give a call and we can setup a time. In the past 2 years, which has been painful, that I have not been able to help more people from this forum. You deserve better. I know change is hard to accept, but this is very good change. I'm in the process of getting OEMs on board so that all dealers will have this to better serve you the customer.
No doubt your setup is pretty cool.
I purchased a ROLO Laser Alignment setup a while back. Immediately, I made changes, improving the accuracy, both in setup prior to aligning and for alignment. No more inaccurate tape measuring, or guessing.
Even had a friend design a company logo. Also did the documents for customer info and incoming / outgoing settings.
Was planning to do alignments for Spyder owners, but opted out except for friends.
Have the alignment tooling and BUDS / BUDS2, all of it stashed away, but there when I need it.
Curious, what type balancer are you using? Mine is a Snap On balancer for cars. Easily balances to within 1/10 oz.
Crazy thing about the balancer, I have helped a couple folks that had vibration issues with the Spyder. Dealers insisted there was no problem after attempts at rebalancing, or even swapping out tires. Remove the dealer balanced wheels, check them and sure enough, not balanced correctly. Rebalance on a good balancer and no more vibrations. Not sure how dealers can screw it up so badly, but they do.
This system does not need BUDS/ BUDS2. The only time you will need to use BUDS is if you replace the steering angle sensor or replace the steering system. I have been told by people, who once were strangers that I was giving a helping hand to that are now friends for life, of the issues that there have had with their Spyder handling that they have grown to accept, were now gone and it was like riding a new vehicle. How about this, NO more bump steering, No more pulling to the left or right when braking. Due to the accuracy of the system and not doing just go enough, these issues reduced or eliminated. You can have "just good enough" and not have tire wear but still have other issues that you accept as the Spyder.
I have 2 Hunter Engineering balancers. One is a Quick Match and the other is a Road Force balancer. My shop has everything Hunter. I was a Hunter Service Tech. for 20 years and left because I was a fixed based operation. I have owned my own shop for 7 1/2 years, so I service and maintain my own equipment including calibration of my balancers and aligner. I have install and service A LOT of equipment and trained just as many techs.
Sounds interesting. I am curious as to how you adjust for camber/caster. Since these are fixed by non adjustable machined surfaces. And how it is that you do not need BUDS to re-calibrate the Angle Position Sensor. Which, if zeroed with an incorrect alignment. Will no longer be zeroed if changes are made. I would think it should at least be checked as if that sensor gets too far out, it will cause a Limp Mode event.
Ron, you are about 3 hours from me in Spartanburg, SC. I would like to invite you to come see for youself and your questions will be answered and please bring your Spyder. I can have camber/caster, toe and thrust angle on the screen with minutes. The answer to your question is caster is not adjustable. Camber is adjustable be changing the ride height. When you can see what I can see, you will be amazed of the changes that happen to the Spyder when you start turning the adjuster on the shock. You really need to see this. Because of what I can see and do, I was able to develop a performance spring package for the Spyder that you can ride and test. The springs have been designed and spec. to the spyder to not change the ride height which will not change the camber. With the development of this tecnology, the after market can develop better and more products because they will be able to see the effect of their products on the vehicles. This will apply to all reverse trikes. Doug, who came to you about a month ago to have new tires put on and then trailed his Spyder home, I reached out to him because he need help, and after do the alignment, he also has a printed record of the alignment, before and after the adjustment,
Let me just say that Sean is a master at what he does. I am glad that he is now able to bring his innovative way of doing this alignment to the Spyder group. He has worked hard and has helped several while developing this system. I for one was about to give up on my Spyder after getting a laser alignment and still having problems. His contacting me thru this board is what save my ridding. It has never felt of been this good. I have put over 5,000 miles since having this done and I am still amazed at how the bike handles. I now have a big grin on my face and I thank Sean ever time I get on my Spyder. His shop in Union is clean and well kept he takes pride in what he does and will explain everything he is doing if your interested or hay you can go next door to the Hardies and get something to eat while he takes good care of your bike. But eat fast cause it don't take long. Oh yea you also get a printout of adjustments that are made. I wish all the success in the world as he moves forward because I understand he has some other things in the works to help us riders. Let me just finish by saying I am glad his shop is only an hour and fifteen minutes from me but I think even if it was eight hours now I would take my bike to him.
oh yah, I remember you had alignment done nearby your house before a long trip, and tires started wear real bad from the nut not being fully tight and affecting toe in/out
Excellent thread..... Only problem is there is no contact info being shared.. I know he is in Union, SC an his name is Sean aka Triniman... But that is it!!!
That's because advertising by non-sponsors is not allowed here! :lecturef_smilie: For that matter, neither is encouraging others to break the Forum Rules! :shocked:
But you could always send a PM! :thumbup:
Yes, of course camber, even though technically non adjustable, can be altered via ride height. Downside though is there is a balance needed between camber and chassis front roll center. If an ideal camber angle of say -1/4 degree were obtained, the suspension arm angles may no longer be conducive to a good front roll center, and / or chassis clearance may not be adequate.
Regarding bump steer, unfortunately, the Spyders simplistic go kart steering design, does not place the inner steering tie rod end in a location that has no bump steer, even in a straight ahead steering angle. Had the designers utilized a wider steering rack, very likely the straight ahead bump steer could have been eliminated. They could have even made a more complex design, with more parts if they utilized a center link on idler arms.
Agree with you regarding a proper alignment will track straight under braking. I have found though, that a setup optimized for minimal rolling resistance with excellent straight line and cornering can get a bit nervous under hard braking. Even though our Spyder has upgraded front suspension, including firmer springs, not just added preload that does not alter spring rate, under hard braking, the front wheels toe out slightly during a hard braking event, and on some occasion, I can feel the front end momentarily squirm side to side. Normal braking is a nonissue. The hard braking, combined with bump steer toeing out both wheels the same amount, causes the squirm.
You mentioned not needing BUDS or BUDS2. That is a curious statement, and impressed you find the need to reset both the steering angle sensor and steering torque sensor after an alignment. Better still, used correctly, the BUDS and BUDS2 is a means to find incoming concerns during an alignment.
Regardless, all the best in your Spyder alignment issues.
Is Sean a Spyder owner / Spyder rider also?
It was not my intention to violate the forum rules. I am sorry to do that. I am working on becoming a sponsor. I think you can PM me, I think.
I do have a 2021 F3 Ltd. It was what started all this. I LOVE my Spyder. I had a Yamaha Raider for 10 years before getting the Spyder.
