wildwillie said:
can somewon tell me about the screws on the end caps,it seems like all they do is keep the end caps on,but others saythey are the adjustments screws.I need to increase the belt tension I only have 220 lbs. and I'm getting a vibration.wildwillie
Do the following in order:
1. Loosen axle nut (large nut on right side of swing arm)
2. Turn adjustment screws on rear of swing arms to adjust belt tension
3. Turn adjustment screw on rear of right swing arm to set belt alignment
4. Repeat steps 2 and 3 until both are properly set
5. Tighten the axle nut to lock the rear wheel in place
A properly tensioned belt will deflect about 7/8 inch with ten pounds of pressure in the middle. When adjusting tension, turn both the adjustment screws the same amount. For example, turn BOTH screws (left and right swingarms) 1/4 turn then check tension, repeat if necessary.
IMPORTANT!!!!
Make small adjustments and check tension often; the consequences of improper tension can be dire (stripped drive belt, destroyed wheel bearings, etc.)!
To set belt alignment you must turn only one adjustment screw. If you adjust only the RIGHT side, you have less chance of affecting the belt tension. If you can, jack your Spyder's rear wheel off the ground, start her up, place the transmission in third and ease the clutch out. This allows the rear wheel to spin while the engine idles.
CAUTION!!!!!
Make sure the front wheels are securely chocked to prevent the Spyder from rolling off the jack! Best case if she rolls off the jack: the engine stalls when the spinning rear wheel hits the ground, worst case: use your imagination!
Make small adjustments of the right-side adjustment screw while watching the gap between the belt and the drive sprocket internal flange. The Operator's Guide calls for 1mm clearance.
If you can't jack the rear wheel you must make a small adjustment on the screw, tighten the axle nut, drive her a bit then check the belt alignment -- bit of a pain in the @ss really...
Once you have the alignment set, recheck the tension. If the tension is off, make small adjustments of BOTH screws.
It's an iterative process -- continue adjusting both tension and alignment until you have them both properly set.
Good luck!
Regards,
Mark
