JayBros
Well-known member
Here's the full scoop from pg. 122 of your owner's manual. If you follow it and particulatly avoid the AAPI SM/ILSAC GF4 category you're not going to go wrong. Listen to all of us engine oil anal guys and you can really fog your brain.
"Recommended Engine Oil
The same oil is used for the engine,gearbox, clutch, and the HCM in theSE5 model.Use the XPS SYNTHETIC BLEND OIL(SUMMER GRADE) (P/N 293 600 121)or a 5W 40 semi-synthetic (minimum)or synthetic motorcycle oil meetingthe requirements for API service SL,SJ, SH or SG classification. Alwayscheck the API service label on the oilcontainer.
NOTICE To avoid damaging theclutch, do not use a motor oil meetingthe API service SM or ILSAC GF-4classification. Clutch slippage willoccur."
