ameobe
This is Bajaron's oil catch can setup & I made a promise to him if I did it I would post the how to.
I had the pleasure at Lamont's BBQ to see it & I liked the idea of not having to empty a can as the oil will end right back in the engine after it's shut down.
1. Universal glass fuel filter. It does come with hose barb fittings but none were used. (to bulky)
2. Foam, Foam installed & the fuel filter & gasket that I removed from the fuel filter.
3. The new setup connected to the engine. (Be sure not to cut the vent hose to short. easy fix if you would happen to though)
4. The final deal.
To sum it up, it is a very cheap & easy mod to keep the oil out of the air box. My only consideration in the process that I didn't do was to take the nut ends of the filter to the grinder & make them round, so the trip into the hose would be smoother, but I didn't & all went well.
Will update after the riding season as to how it worked for me.
4. The final deal.
