BajaRon's Custom Ignition Wire Sets
The wires leading to a coil on plug connector are part of the wiring harness. Not really any different than the wires leading to any other component..like a brake light, fuel injector, etc etc. They are not something that you would swap out like a regular off coil plug/wire setup.
Sent from my SCH-I545 using Tapatalk
...Mr. Snoopy, please look at Ron's post #18 above .......see the picture He posted !!!!!! ........If those aren't wires coming out of the " coil-on-plug ".......then please, please, please be patient and EDUCATE THIS IDIOT as to what they are ? ? ?........Did you think the coils got the juice over the AIR like RADIO WAVES or something.:hun:.........:roflblack::roflblack::roflblack::roflblack::roflblack:.......Mike :thumbup:
Um, ever hear of "wifi" ?
sheesh
roflmao
Somehow, logic and reason continue to elude this thread.
Ron, If I may ask a question...
Will you be producing wire sets for the 1330s?
The 1330 does not use spark plug wires. No he will not be producing a set of plug wires to install something the factory did not.
Those small conductors in the photo are simple power connections for the coil, a part of the harness, not separately replaceable and are good for the life of the bike. Not a service item. Spark plug wires carry the high voltage from the coil to the plug. They break down with age due to the ozone generated and heat and the loss of insulation properties that causes. Intended to be replaced as a service item. The 1330 does not have these components.
WIRES
Those small conductors in the photo are simple power connections for the coil, a part of the harness, not separately replaceable and are good for the life of the bike. Not a service item. Spark plug wires carry the high voltage from the coil to the plug. They break down with age due to the ozone generated and heat and the loss of insulation properties that causes. Intended to be replaced as a service item. The 1330 does not have these components.[/QUOTE]" Thankyou "......Mike :thumbup:
sheesh
roflmao
So have you actually eliminated the plug wires on your Spyder and are now using a " wifi " method of getting electricity to the plugs.....:yikes::2excited: :roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack:....................................This is toooooooooooooooooo funny, Mike :thumbup:
Thanks for the explanation; I honestly hadn't looked under her skirts yet... :opps:
I'm almost disappointed... :shocked: I was looking forward to another great set of "RonWires" :gaah:
Time to get rid of this thing... :banghead:
Yes
roflmao
So, can you retrofit the coil packs to earlier models since we are asking stupid questions here? roflmao
don't answer that.
