I installed BAJARON sway bar today on my 2019 RT. I had installed one on my 2015 when I first got it. I just did not remember how it had improved the handily of it. After installing it today I took a short test ride in some curves and can not believe how much it improves the handily. It is quick a job installing it but I do believe it is worth it. I don’t know what shops charge for installation but it has to be pretty high. The only problem I had was when I finished I found this piece under the Spyder. I remember seeing this piece before but cannot remember where it goes. Can anyone help me?
I also installed Spyderpops missing belt guard. I was not real impressed with it but if it does the job, it will be great. It is real light material and really runs close to the belt. Has anyone had any problems with the guard. I thought it was plastic, but mind is light metal. It does not touch the belt but is close and about the same to the tire. If it don’t give any problems it should keep and gravel out of the belt.
