bad whining noise
mike b
need some help wife has 2009 rs just had it serviced at dealer on the way home about 50mph it has a bad whine or rubbing noise any ideas
With the limited info given, I would say the drive belt has to be adjusted. [properly] :dontknow:
:yikes: But a little bit more info will be needed to verify the diagnosis; Let's call in a specialist! :thumbup: :roflblack:
Rear tire whining
Sounds like the issue I ran across. I had noticed the rear noise also. I sat down behind the rear pulley and eyeballed the line of the belt. It was just a tad off. If you have a good eye then you will notice a slight kink in the belt..
