Bad Boy (same as Seibel) Air Horn Install tips video
when I was looking to purchase a horn and wiring, I came across this wiring kit make by WOLO for $8.53. It was the only one I ran across at the time. It does not have the relay itself enclosed, only a socket for one...I think the assumption is the relay comes with the horn.
Wolo (MCHWK-2) Air Horn Wiring Kit
http://smile.amazon.com/gp/product/B005I4DNP2?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s01
<my intent is NOT to slam the stebel kit in any way>
Byen Merci :)
not the same
The Stribel and the "bad Boy" horns are NOT the same by a good margin. I have the Stribel on my Valkyrie and a badboy on the V-Max ( bothwith relays). You can easily tell the difference and the Stribel is a real step up.
OEM horn is useless. A Stribel horn is my next farkel.
Kaos
How are they different?
Kaos
i thought they had roughly the same sound and decibels.
Thin air up here
Maybe it's the thin air at 6,000 ft but I honked them side by side( with freshly charged batteries) and I'm NOT mounting a "bad boy" on my :spyder2:. THe Stribel is the way to go.
Wimpy OEM horns cause:
Kaos
From what I have read and re-read a dozen times trying to wrap my brain around this issue, I have discovered that DB levels (or claimed DB levels) means nothing as stated by manufacturers.
The first problem is how the manufacturer has measured for a DB level. There appears not to be a standardized testing method used; thus stated (advertised) DB levels are not consistent among the various products. Testing has been found to have been done at varying distances from the source; thus nullifying any meaningful comparison between two products.
Also, the "note" of the horn(s) can make a difference in how well it is heard by the human ear. It is also known that a more dissonant sound, typically provided with the use of two horn reeds, is more noticeable than a truer tone/note despite any fact of any difference in actual DB levels (to a degree).
Personally, I would like a loud horn sounding exactly like car tires screeching to a halt on hot pavement. I suspect it would get people's attention if needed. ;)
Did not know that
Side by side , it's obvious they roll out of the same factory. I bought a bad boy three years ago at HF for 35 bucks. It plays a loud kind of high pitched chord. Sounds like two trumpets. It's been great. I did use the relay that came with it.
Me too!
Stribel horn arrive today and is already mounted. Easy farkel, and functional too as the stock horn is usless. A few minutes of wiring tomrrow and it done. Now i have 3 stribels and one bad boy.
Kaos
Your Installation of Stebel on your 2013 RTL
I can't recommend enough the Universal Plug-n-Play Wiring Harness for Motorcycle Air Horn
you can buy on Amazon for $19.95. It makes the install very easy and has a heavy-duty 30 Amp relay built in. It's plug-n-play folks! No cutting, splicing and/or soldering. Very easy!
I used one on my '13 RTL when I installed the Stebel air horn.
If have a couple of questions that I need help with. Which side did you install your horn on, and the second question concerns the correct way to wire the plug and play wiring harness to the Spyder and the horn. Thank you in advance for your time and information/instructions. Dave
On my '13 RTL I had to remove the frunk to install the horn in the same location as the stock horn. There's a black plastic piece that has a small (2 x 2) hole cut in it that the OEM horn opening sits next to. You have to take a dremel tool and expand that hole so you can reinstall it over the Stebel. It takes a few times to measure, cut, fit, measure again, cut a little more, refit, etc so that you don't cut the hole too big. Then, it all fits back together.
As far as the wiring goes (now, this is off the top of my head), the lead with the fuse hooks to your battery. The relay is already attached and its lead connects to both the horn wires and the horn itself.
Hope this helps.
Feel free to call with questions.
Jerry
317-445-1411
bad boy
Just posted to your video. I knew I should have looked here first. Im guessing our RTS are a tad different. I tried to mount it where you did to no avail, no space, Mine has a "junction" for my battery wires on the left side of the bike right at the top of the Frunk. Looks likes yours doesn't have it there? Trying to get it set up tomorrow, so any input from yourself or others with 2013 RTS is greatly appreciated. Thank you in advance.
Hi there! I know exactly what you mean as far as the location! I installed mine on the right side of the bike, right under the plastic by the fog lights! You'll have to make a bracket n bolte it to an existing body bracket on the bike! Can't missed! Once you remove the plastic you'll see it! I recommend using the relay switch! To me it sounds louder with it! Hope this will help!
AIR HORN
I also have a 13 RTL and have been considering on getting an air horn. Did the air horn fit in the same position as the oem part? Did you have to modify anything to make it fit? Approx. how long did it take to do the installation. Thanks for any input.
See post #32.
It took a couple of hours, if I remember right. A guy I know, who's a mechanic, helped me.
I mounted mine - and its relay, fed through a 20A fuse from the battery - in the nice big empty void where the original horn sat.
attachment.php
All this talk about Stebel, I had to get one and install to see for myself what others are saying. Well, I really like it!
attachment.php
attachment.php
attachment.php
attachment.php
...here are a few more pics and of the 20 APM fuse. I used the relay that came with the horn and made my harness. This made wiring really neat and clean.
attachment.php
attachment.php
attachment.php
attachment.php
I can't imagine that ANY handlebar mounted switch can take anywhere near those amps.
There has to be a horn relay someplace in the circuit. Evidently it's sized with enough safety factor to absorb the additional amps.
Few points to consider.
1. Just because a circuit is fused at 5 amps, does not mean it uses 5 amps. You have to have a buffer in there to compensate for the 'current inrush'. The factor I use is 150%. So if the load is 3 amp, you multiply that by 150%. 4.5 amp. You use the next fuse size up....5 amps.
2. More than likely, there are other items on the same circuit as the horn. I have ordered full electronic manuals for the Spyders....but this is based off other vehicles.
3. There is a reason the horn manufacturer includes the relay. Most of these air horns draw 3 times what your stock horn does. The OEM wiring and connectors were based on that stock load.
4. Damage does not happen after one or two operations. It takes a bunch. But here is what happens....you break the weakest link. Might be a switch, might be a fuse, might be a connection. When you do find it, you get to spend a bunch of time on a Easter egg hunt that could have been totally avoided.
One other point to consider....orientation. The horn needs to be straight up and down, no more than 15 degrees off. Otherwise, the bearing in the compressor housing will get destroyed.
The Stebel is made in Italy. Wolo Bad Boy is all China.
