Anyone replaced the OEM antenna with a Short antenna? How is the reception?
DougC
Ok I'm still looking into the speaker issue but had anyone replaced the OEM antenna with a short stubby antenna and if so how was the reception?? Thanks
I bought the "shorty antenna" from Custom Dynamics" and used it Tuesday on a trip where I was about 50 miles from a local radio station before I got any signal loss. :2thumbs:
that one works good. I have the one from stubb antenna that works good for me. they come with two adaptors.
The WalMart shorty worked fine for me when I lost the OEM. Still have it "on the shelf" in the garage, just in case. :yes:
It figures, that I'd be the "Odd Duck" on this one... :shocked:
I tried the Shortee that Custom Dynamic sells...
The reception was noticeabley poorer, than with the OEM antenna.
However: I live here in the Mountains; so reception is always an "iffy" thing around here...
I went back to the OEM "longstick", and haven't regretted it... :thumbup:
Good point Bob. The Custom Dynamic's antenna works great for me. But I live in an area that the altitude changes are calculated by inches. :ohyea:
2014 SPYDER RT-S ANTENNA
Ok I'm still looking into the speaker issue but had anyone replaced the antenna with a short stubby antenna and if so how was the reception?? Thanks
:yes:I just broke off my antenna, when i bent it over to put the cover on it! DON'T MAKE MY SAME MISTAKE, I GUESS THEY ARE MEANT TO BEND THAT FAR! The fiberglass snapped off just above the attachment nut, which I cannot get loose. I stopped trying, until I'm sure it is suppose to come off, I don't want to break something else, I'm good at that! Anyway, if I get it apart, I may try the stubby mentioned from WalMart, that hopefully is not so delicate, and I'll post my outcome! Good luck on your choice!
TRY THIS
:yes:I just broke off my antenna, when i bent it over to put the cover on it! DON'T MAKE MY SAME MISTAKE, I GUESS THEY ARE MEANT TO BEND THAT FAR! The fiberglass snapped off just above the attachment nut, which I cannot get loose. I stopped trying, until I'm sure it is suppose to come off, I don't want to break something else, I'm good at that! Anyway, if I get it apart, I may try the stubby mentioned from WalMart, that hopefully is not so delicate, and I'll post my outcome! Good luck on your choice![/QUOTE........................:yikes:...With the mast gone put a 7 mm socket down there and vise grips on it and you should get it loose......you might want to squirt some " break-away " or something similar on it first..........................good luck......Mike :thumbup:
