Anyone changed their 1330 trans filter yet?
Hello AeroPilot,
You posting abt using a cross-pattern when tightening the SE6 transmission filter module-to-engine case reminded me that I don't even know what that torque is supposed to be. Do you know, by any chance?
Regards, PatrickH
Clean off the surfaces and Remember to be easy on the cap screws when torquing it back and use a cross pattern to even out the seal on the filter module to the engine case. And the torque is just in inch lbs, so go easy. ....
Hello AeroPilot,
Regards, PatrickH
Patrick, AeroPilot's post on page 2 of this thread about using that cross pattern was made way back in June 2019, so unless AeroP subscribed to this thread, you might never see a response from him. :dontknow: Similarly with your other request - it is a thread that started a while ago, so you really should check the dates on any posts you want to query/as questions of the poster. :thumbup:
Sure, possibly someone else in the know might answer instead, but maybe you'd be better off sending AeroPilot a PM direct? (Include a link to this thread tho! ;) ) Worth a shot! :ohyea:
PatrickH -- first allow the gearbox to fully drain. Then remove the HCM filter Torx screws. Gently gently twist and pull the filter off. There shouldn't be much oil but a couple of paper towels underneath would be good. Inspect the various gearbox openings and make sure you have collected all O-rings. Wipe things mostly dry. Put a bit of oil on the HCM O-ring but not the outer seal. Gently gently push the filter back in place. Hand tighten (no tool) all the Torx screws. Then in three stages cross-pattern tighten the screws. Three stages is the minimum -- you do not want to bend the housing of your $100 filter and crimp the outer seal. Final torque is 11Nm/97inlb (Service Manual Supplement page 246). I used a 1/4" digital torque wrench. I'll be doing mine for the second time this weekend because the oil was dark (but otherwise clean) when I bought the RT-S at 77K. The clutch looks fairly easy to replace but I just as soon as leave it for the next owner. Best wishes.
Hello PW,
I'm about to replace my transmission filter. When you do a 1330 transmission filter replacement, is the gasket alone adequate to seal the cover plate against leaks? Or do I need to get some gasket sealer before I replace mine?
Regards, PatrickH
The seal on the filter is all that is needed. I have done 4 changes and never used any additional sealer. Never had a leak. It is a messy job so I lay a large piece of cardboard down to catch any oil that gets past my pan.
Run the engine for a while to ensure mo leaks before putting the Tupperware back on - this also purges any air that maybe in the system.
I changed mine just before our NTA trip at 21,000 miles. Early I know, but did not want to have to have that done during the trip.
It's more involved than just the standard oil and filter change, but that's where you start by draining all the oil out first as you will still get a fair amount out of that cover.
It is located at the bottom far right of the motor on the right side. I removed the right side black plastic support piece that holds the snap on vented Tupperware and the headlight adjuster as well as the right side short skid plate below it. This gave me direct access to the 10mm (head) bolts on the cover as well as a strait shot for the oil to drain.
The cover and filter are one piece so remove the bolts and pull the old cover off and replace with the new and bolt it on. Fill with oil (make sure your drain plugs and back in) run the bike and check for any leaks then button it all back up. Have a beer and congratulate yourself on saving a lot of $ that the dealer would have charged you.
If you have the time to wait you can find the filter on line for less than the $105 I paid.
Does anyone have pictures or link to a YouTube for this?
I did mine at an oil/filter change a while back. Not a hard job. No BUDS. Just adds maybe 45 min to an hour to an oil change.
Lew L
Hi Pete,
Yes that's it. Change it at an oil change as you have to drain the oil anyways. Metric ball head hex wrenches help. Get and old towel to put under the filter as you'll get another 1/4 to 1/2 cup of oil draining out. Tighten in steps with a criss cross pattern and NOT too tight. Inch pounds stated in the thread somewhere. BUDS not needed, just lit it warm up a minute as you check for leaks. Shift int 1st and Reverse, then drive off for a test ride.
Good info in this whole thread.
Lew
