Anyone built an RT622 Trailer Kick stand?
Has anybody built a kick stand for your Can Am Trailer?
I need something simple to support the tong. Using a jack stand now but a simple trailer kick stand would be nice.
If not building one where can I buy one?
If you go with the CanAm stand, you should install a trailer hitch pin to keep it up on the tongue when travelling. The dinky spring thingy that comes with the stand doesn't hold it up. I found this out on a road trip when I stopped for gas, the stand was dragging on the pavement, and I had to secure it with a bungee cord. Drill a hole through the stand and tongue with the stand in the up position. Make sure to drill the hole 1/16 in larger than the diameter of the pin for easy in/out. This fix solved my problem, and hitch pins are cheap. This should work for you.
https://www.amazon.com/Buyers-Hitch...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
