Deanna, I have a 2016 RT. Thank you.
In the next month I will be replacing my Yokohama rear tire. I average about 10K miles a year and I am a solo rider and not an "aggressive" rider. About two years ago after purchasing the trike used, my mechanic replaced the original Kenda's with Yoko's. He told me that the front tires would probably last 50K miles. After 16K miles, the front tires still look new and I am very happy with that selection and I believe the 50K plus expectation will be a reality. I was also told that the rear tire would last approximately 18-20K. After 16K miles I believe that projection is correct.
I would like a tire that would get me a lot more than 18-20K miles. It appears that I can use either a 205-55R-15 or a 215-60R-15 with a symmetrical tire pattern. Can you guys suggest to me a longer lasting rear tire and estimated mileage? I will appreciate your suggestions and thank you.
... My Yoko's have worked well and traction has always been good, but like I stated I would like more than an 18K tire life. I ride solo and I am not an aggressive rider and average about 10K miles per year. ...
ButterSmooth, what brand of "mildly asymmetrical" tire are you trying out? What year and model of Spyder do you have? Thank you.
If I were getting 18k from my Yokohamas, I'd be overjoyed. The one I'm replacing tomorrow made it to the wear bars in 7k miles. The Kuhmo before that made it to 9k. This time it'l be an asymmetric 205/65R15 with a 740 utog 92H -- the last was 215/60R15 with a 620 utog 94H. Hoping for mileage like you get! I used to look for a low utog in search of better traction.
jbs1218,
The General Altimax RT43 tire has "Replace Tire" embedded into the tire.
Deanna
I replaced my stock '13 RTL tire at about 9k miles, my first General Altimax RT43 lasted about 27,000 miles before I replaced it (and didn't have the replace tire warning yet, but was planning a loooonnggg trip) When I sold the '13 Spyder at 39,000 miles the 2nd General Altimax RT43 backtire looked brand new.
It's a Yokohama Avid Ascend GT 205/65R15. The three inner rows of tread are just slightly off center, but the tire is marked 'inside' and 'outside'. It's going on a 2020RT (not RTL). This is tire #4 on the rear -- I'm beginning to feel like a tire tester. The quick wear may have something to do with the 'quality' of the road surfaces around here.
https://www.tirerack.com/tires/tire...HR5ASCGT&vehicleSearch=false&fromCompare1=yes
Those are very impressive numbers. What tire size are you using? Thank you.
General Tire Altimax RT43 215/60r15 was $80 back in '18...
Interesting that your Yoko's performed so poorly. What tire pressure are you running in the rear? I have kept the pressure at 24 psi on my rear tire.
