As I get into the deconstruction of the trailer I purchased, finding what needs to be done, it is surprisingly little considering its 22-year-old status.
Bushtec has metal Schraeder valves to replace the problematic plastic valve in the tongue.
Monroe MA785 look to be a direct fit.
My heim joint was toast. I found an identical replacement at McMaster Carr. PN 4444T24. Made by QA1, the suspension folks for hot rods and racers, the CFR10Z is identical, down to the zerk fitting. It was about $11.00.
The factory Bushtec pin and lock bolts directly into the Can Am hitch... a perfect fit.
My latch is worn. Bushtec still has replacement parts, which is almost unheard of today, with many manufacturers giving up support at the 10-year mark.
The thing is huge. I can sit in it. My spouse, considerably smaller than me, literally could take a bath in it.
Once I to the get wiring, probably from ShowChrome, I'll decide on 4,5, or the complete 7 pin plug that's common on RV's. But the funky 6 pin plug currently on it will go. 4 and 7 pin parts are in every AutoZone and NAPA everywhere.
