ANTENNA
PW2013STL
Does anyone know the part number and cost for the BRP short antenna?
I believe these came out with the 2016 models. I just shapped mine off and do not want to replace it with the long one that it came with.
Update,
I found it on Cheapcycleparts.
Antenna - 710005084 for $57.99
Wow that ain't cheap. You can get a shortly a lot cheaper than that at Walmart.
I will be checking that out for sure. Good thing I don't listen to the radio so I have time to find a cheap fix. To bad BRP doesn't sale the little cover for the hole as I would than just plug it.
New antenna with better range and much more solid, Just got this from Spyderpops and it comes with a new style boot that won't fly off and works with half or full cover without breaking, what do you think, looks good don't it?
about $25.00 shipped to you
Cruzr Joe
How opportune....
Spyderpops has one to fit the bill....check with him as mentioned above....:thumbup:
Cruzr Joe
Thanks Joe,
I just ordered one.
Les
Update,
HI, I got my short antenna(part # 710005084)and 2 antenna bases from Pitbull.
Short antenna..............................$57.99 and 2 antenna bases ( $15.99 each). I have a 2014 RTS-SE6, see pictures:New Radio Antenna on 2014RTS-SE6 001.jpg New Radio Antenna on 2014RTS-SE6 002.jpg
Look at "My Album". I replaced my original last month. It took me about 5 minutes to change out the original.......long antenna. I did not use lock tite. The radio stations are clear. Deanna
Rubber shorty can be purchased at Walmart for under $20. Comes universal with plenty adapters. Works just fine.
Hi Joe,
You've mentioned the reception several times now...
Since I get ZERO reception with my OEM setup: can you please explain how much better it pulls in stations, than your OEM antenna did?
(If that is in fact the case... )
Thanks! :D
I've been fighting with my OEM reception since the day I brought the bike home... It's down to either a bad antenna, or a bad receiver... :shocked:
Or?......
Hi Joe,
Have you checked your hearing? No offense, but as we get more mature, sometimes.......
(That's why I type bigger, so everybody can hear!)
~Sandee~
I bought a small rubber antenna from walmart at cost of 10.00 CDN. I find that it woks better than long stock antenna.
Just a question, how long is the "long stock antenna"
I know the one I have is a pain when getting the covers on and off the bike
You have a short (compared to older models) antenna, the original is about twice as long
Cruzr Joe
~Sandee~
:shocked:... what? :D
My ears are fireproof, bombproof, and ready for War! nojoke
As I was listening to some "light music" from Yngwie Malmsteen today (look him up...), I heard every note that his guitar played... :bowdown:
Seriously: I DO have a reception problem, and am wondering if it's worth spending $25, to see if a new antenna might solve it.
If and when you get a new (shorty) antenna DON'T use any locktite on it. Had to cut off my wife's antenna to get a socket onto it to get it out. Was locked in there tight!.
(her bike has always had a reception problem) Cleaned out a crap load of blue locktite from the threads. Screwed in a Walmart shorty in without any locktite and took it for a ride, it had to have doubled the reception distance for her.
Now ordering one of the Spyderpops antennas to see if it increases distance even more.
