Sorry Spin, we can't get Vredesteins here in Oz any more; but maybe some of the nearer Spyder Ryders with Q5's could help? :dontknow:
Thanks for all your help Peter. It is much appreciated!! I have not been able to find the Vredesteins in 215/60 on TR or DT. Do you know where I could find them?
The 225/60 is even taller than the 205/65. I haven't heard of anyone using that size.
I have discussed your tire questions with Peter .... I NEVER use Nominal tire measurements when I recommend a tire/s .... I also use " Revs per mile " measurements, the 205/60-15 gives 815 Rev's per mile .... the 225 is at 815 revs per mile ..... the difference is basically MINISCULE ..... From info from Peter the 225/60-15H is the better tire and will fit ( all tire mentioned were General Altimax RT 43 tires ..... Mike :thumbup:
Because the OP would like a tire close to 225/50 - 15, I would recommend the General Altimax RT43 with the H or V rating in 215/60-15. To the OP this size will correct the speedo / odometer reading. .... and a very good PSI for this tire is 18-19 ...... good luck .... Mike :thumbup:
I just saw this after I posted!!! Back to the Drawing board!!! What do you think of the Michelins?
Yup..mine would max out that tire. I would like a v rated tire.I gotta ask does anyones stock Spyder go over a 118 MPH?
In spite of all the other recommendations and comments on the 205/65, you continue to look at the 215/60? :dontknow:Thanks for all your help Peter. It is much appreciated!! I have not been able to find the Vredesteins in 215/60 on TR or DT. Do you know where I could find them?
Are you getting it installed by the Spyder dealer, or by a tire shop?
As mentioned earlier, the 205/65 fits perfectly and was readily available.
The question was raised and I have not seen it answered: where are you having them mounted? Have you verified with them that they can/will mount tires on Spyder rims? Will they be able to balance them?
The shop that does much of the work on my 4-wheeled vehicles was willing to mount and balance the tires. I asked him if he minded whether I provided the tires, as some shops will charge extra. He said it was no difference, but he might be able to save some on the tires. In fact he was able to order them in (next-day delivery) for very close to the same price that I would have to pay Vulcan Tire.
I had done my initial shopping at Vulcan Tire and found some good prices. I talked with the guy that owns the Muffler Brothers franchise where I get my car work done, since he is also a motorcyclist. Although he had no problems with me bringing in the tires, he offered to see if he could get a better price. I think his total was only about $5 more than what I got from Vulcan, I figured the lack of hassle on my end was worth at least that much. :thumbup:Question were you able to get Vredestein tire from a different supplier , and who was that ..... Thanks ... Mike :thumbup:
Not sure where he ordered them from. :dontknow:
