Another Thread about Heat And The RTs
STOCK
Just came back from 2 week trip, a couple of +100 degree days, rest upper 80's low 90's. Was the RT hot? You bet but with stock foot pegs feet never felt any hotter than the left foot. I too have been following all the different links to how hot the RT is. Wondering how many folks who have a problem rode 2 wheels, especially Harleys. All bikes are by nature hot especially in the "netherlands".....so riding the RT, heat wise, has not been all that different from the Harley. If the Can-Am is your first bike I can see where it would feel extremely hot to you. But, in my humble opinion, I don't find any more uncomfortable than the 2 wheeler.
Trust me we're not imagining in. I have about 300k on 2 wheelers, some hot, most not. I went as far as taking IR temp shots when i first got Spyder. Right tennis shoe would read at least 20 degrees higher than left. I plugged the bottom hole and put on cat shields and now the readings are only a couple of degrees different.
Can only speak for myself and I've been riding for 55 years. I too know what NORMAL heat or expected heat issues are. What I experience on the Spyder is NEITHER. Glad you had a good trip with ONLY a couple of days at 100 degrees. Come down my way.....that's the norm.
My Rt was one of the ones with blistering heat issues. I do ride with boots and on a 95 degree day had to pull over and take off my boot, because it was flat on fire and no denying it. My foot was red and swollen and pretty tought to get back into my boot. My wife complained that her right side was too toasty as well.
Got the SpyderPops top block off plate and cat shields, which my wife loved, but did little for my flaming foot. Added the FanCan and now my foot was finally comfortable. It does tend to blow heat up through the gap between the seat and tupperware to some degree and wife complains a bit more, but at least we're out riding. There would be no way I would be able to put up with the flamin foot when temps got to be 10+ degrees hotter.
I've thought about taking off the FanCan and cutting holes in the swoop area, but that's a pretty permenant mod. If it did the same or more for blowing air around the seat, I would essentially damage the bike for no gain.
I have not tried blocking off the bottom port only and leaving the top open. It just seems it would redirect more air on the boss and she wouldn't be too happy about that. Perhaps someone could chime in who's tried the combo and tell us the result?
So I guess the heat around the seat is self inflicted, but still sure beats the heck out of a flamin foot. Stock was absolutely unbearable in Phoenix, so something had to be done.
I didn't have a problem on my '09 GS, although I had mods too help cool it down. On my 2012 RT limited I have not done any mods. Always wear heavy boots. I have not had any problems with hot foot as of yet with stock foot pegs. 200 hundred miles have been going around forty mph. in two group rides of 200 or more bikes. So far so good. Put on 700 miles in the past 2 weeks.
Can get very hot even with Spyderpops products. I feel it more on the back of my calves then on the foot. I knew that heat on the feet and legs was a major issue with the Spyder before I purchased I just was hopeing that I would be one of the few that did not have the problem. What makes these few without heat issues I dont know, but whoever figures it out will be a very rich person.
Thanks Dave! :thumbup: I appreciate this input; I fear that an awful lot of the complaints may have actually been "owner-inflicted".
I can't actually suggest this because it's probably stupid and dangerous; but if somebody with the stock footpegs could check out where that airflow is in relation to their feet it would really be useful...
This is probably about as good an answer as one could ask for. All be it while wearing tennis shoes.
I purchased an IR so I could keep a record of L/R foot temp variances. Also record the ambient riding temps they were recorded in.
Sorry, I guess since I, as you say, experienced ONLY a couple of days at 100...I shouldn't have posted my thoughts on the subject. I knew when I posted I would get a little blow back. I'll think twice before I do that again! And I have only been riding about 30yrs. And for the previous poster....I never said you or anyone imagined the heat issues.
RTs heat on right side
I thought I would chime in on this one. The wife and I just completed a 1,300 mile run from Oak Harbor WA to Lancaster CA. We took US 101 down through Astoria OR to Eureka CA through Yuba City Ca and down through the San Jaquine Valley at temperatures exceeding 100 degrees. Neither of us experienced any discomfort from heat on the right side. Now the outside temp is a different story. Oh, we have a 2011 RTS with Seal full boards and yes, I do prop my boots on the very front top tip of the board.
Just out of curiosity, has anyone gone from having a FanCan to removing it, blocking off both sides and cutting holes in the swoop area instead. If so, was there less heat coming up through the seat that way? How about blowing back up on the back of your legs. Just wondering if this was a better option than the FanCan:dontknow:
Phil (Texas) has done all of the above and has seat heat problems. Almost certain he mentioned it in a post here http://www.spyderlovers.com/forums/showthread.php?41690-Hot-Air-Solution-for
Tho, he, to the best of my knowledge has never used a fancan.
Originally Posted by cjackg
Are you running these tests with both upper & lower Spyderpops blocking plates in place ?
(Even if it doesnt work, it is an impressive test. Phil never does things partway!)
Yup. Top and bottom blockers are in place.
Phil, Tyler TX- from my iPad3.5 using Tapatalk HD​
Just cause the title of the thread was "begging" for it
:bdh::bdh:seriously the Spyder has a heat issue on the right side, who knew? :shocked: :roflblack:
I installed the Seal Floorboard.I don't have a heat problem until I am fully stretched on the floorboard.If I move my foot right up to the front tip of the board it is much better.I recd the Spyderpops plate and will install that in the next day or so.
I also have a stock RT, no mods and rode Harley's and Motoguzzis for years in rural Georgia, With daytime temps in the 90 to 100 degree range with 100% humidity it's hard to see the heat as being a Spyder issue. all big displacement bikes create tons of heat and I suppose you get used to it over time. If you are new to riding and live in a cold climate it must e a very dramatic change as campared to winter riding.
I never had a problem with heat with my Spyder, But i had many bikes that thew out more heat than the Spyder did, So i am use to it. That said Brp markets the Spyder very heavily to people with no or little previous Motorcycle experience, So by now they [brp] should have solved the heat problem, And it is a problem for many just read all the posts going back from day one.:dontknow:
:thumbup: :thumbup: :thumbup:
